Old 03-11-2004, 06:05 PM   #1
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
$28.99 for a torque wrench... did I was my $
I made this big decision was gonna take our Airstream into the Ford dealer (at the same time I got service of the E) and they were ready and have the lug bolts torqued and the brakes adjusted....
And then I thought about the cost of the one-time torquing and the brake adjusting and decided I would do the cost effective thing....
Now tell me again....is it just like my '51 Chevy....you use a screw driver and rotate the wheels and get them sort of tight with the drums and then back off a wee?
On the torquing....85 lbs. right? This torque wrench I have ordered is from Toolsource.com and it is a CTI??? in LA or Sacramento....don't know which....comes with a case must really be a delicate instrument, right....
Did I do the right thing?
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 03-11-2004, 06:10 PM   #2
Well Preserved
overlander63's Avatar
Colfax , North Carolina
Re: $28.99 for a torque wrench... did I was my $
I am not 100% sure about the brake adjustment, but it sounds good. The torque wrench should be good enough to be acceptable for what you want to do with it, after all, you are not assembling an engine, or performing brain surgery with it, so the cheapie-deapie should do fine.
Intelligence is learning from your mistakes. Wisdom is learning from others' mistakes.
Old 03-11-2004, 06:14 PM   #3
Images: 59
Torque wrenches
Kistler,
I read the latest brake adjustment specs from Dexter, and yeah, hasn't changed a bit.
If you want to get fancy, buy one of those brake adjusting bars that looks like a short, bent two-ended pry bar. Sure makes the job easier!
Congratulations on your torque wrench
Old 03-11-2004, 06:27 PM   #4
Kistler's Avatar
2002 25' Classic
I appreciate your advice you guys....never took Auto Shop
K
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
