Old 06-02-2015, 05:17 PM   #1
2015 30' FB FC Bunk
Ayer , Massachusetts
25,000 BTU Max Limit on Propane Grill Supply
My trailer has a quick-connect for a gas grill which is great, but my Camp Chef stove is rated at 90,000 BTUs. Not sure why it is limited to less than 25,000, I plan to keep the flame low and will only use 2 of the 3 burners. I can get the stove wide open on a 5lb bottle. My trailer has much more capacity.
Any thoughts on this? should I look to mod the propane connection?
Ted S. is offline   Reply With Quote
Old 06-02-2015, 05:32 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
With most gas grills, you connect to a high-pressure source (no regulator at the bottle), and regulate the flow at the grill. With a grill hooked up to an RV's propane bottles, you're tapped into the low-pressure side, and flow has already been regulated at the tank, so trying to regulate it again at the grill is problematic.
The normal modification routine is to modify the grill to remove the regulator and go with a simple valve instead of a regulator, so that your trailer's setup is unchanged. Modifying the trailer's regulator setup instead is risky and could void your insurance coverage in the event something goes wrong.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-02-2015, 05:36 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
It has to do with the flow rate available from the regulator. I don't know the rating of my grill, but it is a small single burner, so probably less than 40,000 BTU/hour. Twice now my water heater has failed to light when using the grill and the stove in the trailer. I suspect insufficient flow through the regulator as the cause. It is easier and substantially less expensive to restart the water heater than to change the regulator or add another one for the grill. The propane system is designed to support the stove, furnace, water heater and refrigerator. Adding a grill increases the demand for propane significantly but should be OK as long as you don't run it wide open along with everything else.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 04-30-2017, 07:48 AM   #4
2015 30' FB FC Bunk
Resolved.
Wanted to follow up. I have been using the grill from the trailer supply for some time with good success. I don't run it on hi, just medium.
Old 04-30-2017, 07:57 AM   #5
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
We have a 2 burner Camp Chef stove, and ours works great too when connected to the AS provided quick connect propane outlet in the front. I normally use either low or medium, and can't imagine needing to cook on high. Great stoves by the way.
SeaLevel is offline   Reply With Quote
13500 BTU vs. 15000 BTU Eddie25 Furnaces, Heaters, Fireplaces & Air Conditioning 14 12-20-2013 11:50 PM
HOT IN TEXAS!!!! Upgrade a 13,000 BTU to a 15,000 BTU? Does it help? bowhead13 Furnaces, Heaters, Fireplaces & Air Conditioning 47 07-19-2013 12:02 PM
TV Dodge Ram w/ 10,000 lb weight limit helenl Tow Vehicles 4 03-06-2013 06:18 AM
15K BTU Brisk Air vs. 15K BTU Penguin adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-23-2011 10:32 AM
