Old 05-21-2014, 10:41 AM   #1
Airstream Newby
CMSmith's Avatar
1975 25' Tradewind
Florence , South Carolina
1lb LP bottles for water heater?
I only have LP for my water heater at this point. My tanks are old and in need of painting and re valving to make them up to code so I was thinking about getting rid of them. Has anyone used the little 1lb tanks adapted to run the water heater? This would allow me to free up the two huge tanks on the A frame, reducing weight and also maybe opening up a space for a light storage bin. I would tap into the line right below the water heater, but what sort of regulator would be needed for this? Do you use the same type of regulator with adaptors to make the small tank fit (they make them, so clearly those tanks are used in place of full size ones for some things).
Has anyone done this? Any suggestions or advice? If done, anyone want two 30lb tanks that need to be painted and updated? I also have a tank cover from, what appears to be, an 80's model Airstream.
CMSmith is offline   Reply With Quote
Old 05-21-2014, 10:47 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
It might work... a pound of propane is roughly 91,502 btu's a typical water heater needs 12,000 btu's of input. Seems an expensive way to go though. I think you would need a different regulator. IMHO the easiest method would be to get a cheap 20# grill tank and paint it silver.
Aaron
WBCCI #XXXX AIR #2495
Old 05-21-2014, 10:53 AM   #3
1974 Argosy 20
Kooskia , Idaho
A one pound gas tank has about 20,000 BTU of energy in it. Your water heater, as I recall has about an 8,000 BTU burner. So, you would get about 2 1/2 hours of burner time from a tank. I don't think it is a practical solution.
Yes, if you did it you would need a regulator to go from the high pressure tank to the low pressure needed for the water heater.
What are you using to cook with, and to run the furnace?
Old 05-21-2014, 10:57 AM   #4
1974 Argosy 20
Kooskia , Idaho
A gal of propane has the 92,000 BTU, not a pound. A pound is aproximately 1/4 of a gal and that is where my 20,000 BTU came from.
Old 05-21-2014, 11:22 AM   #5
Airstream Newby
CMSmith's Avatar
1975 25' Tradewind
We have never lit the furnace (Suburban) and just use a couple small ceramic heaters. Our cook top and stove we took out and just have a larger counter space and a big storage cabinet. All of our cooking is done outdoors because we do not like how cooking smells seem to permanently fix themselves into campers that are cooked in a lot. It is a personal preference. I have never filled our tanks since purchasing the camper a bit over a year ago. Neither seemed full, though one is now empty and the other is not far behind. I am guessing that we have gone through about 8 pounds of LP in our dozen+ trips. It was just a thought, maybe our tanks were fuller than I thought when we started.
Our 6 gal water heater usually seems heated within 30 minutes of firing it up and it only burns again when we shower. I may just end up with a 20# refillable tank not mounted on the A frame.
Old 05-21-2014, 11:37 AM   #6
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I thought there were 8 pounds per gallon, and four quarts per gallon.
Old 05-21-2014, 11:47 AM   #7
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I'll put in another objection to the original idea: Those 1 pound cylinders are expensive, relatively speaking (environmentally wasteful, too). I'd go with the 20 lb bottle instead.
How do you cook when it rains? Still outside?
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 05-21-2014, 12:05 PM   #8
1974 Argosy 20
Kooskia , Idaho
Just some statistics:
Propane weighs 4.2 pounds per gal at 60 F.
So, one pound is about 1/4 of a gal.
Propane has 91,500 BTU per gal.
So, a one pound tank has about 23,000 BTU of energy in it.
Water weighs about 8 pounds per gal, not propane. Quarts have nothing to do with the issues.
Old 05-21-2014, 12:09 PM   #9
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, a 30 lb tank holds about 7 gallons of propane; That would be about 4 lbs per gallon wouldn't it?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-21-2014, 12:28 PM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
No. They're intended for portable equipment. They don't have shutoff valves.
You can get smaller DOT cylinders if you just want to save space. 4, 5, 6, 10, and 11 pound cylinders are all readily available. They all have the same valves a 30 pound cylinder would. If cost is your main goal then 20 pound cylinders are cheapest because they are so widely used.
Then where are you going to put the tank? Under the trailer? You have to think about how you're going to mount and secure it.
The only adapters I've seen are the "steak saver" adapters that some people use so they can run their grill for half an hour after exhausting the gas supply in a larger cylinder.
Don't screw around with high pressure propane plumbing. Use the standard products with the minimum possible number of adapters and extensions. Fasten the tanks in place properly.
Aside from the obvious fire and explosion risk, there is the risk of frostbite from liquid propane. The injuries can be disabling.
Old 05-21-2014, 12:30 PM   #11
Airstream Newby
CMSmith's Avatar
1975 25' Tradewind
We always have a "non cook" option if it is raining. Sometimes that involves a local restaurant. My biggest thing was getting rid of the huge tanks on the front for just a single use. Looks like I will scratch the original idea in favor of the swap out tanks (just not mounting it on the front). Thanks for the input.
Horizontal LPG Bottles on "Limited" models Dwight LP Gas, Piping, Tanks & Regulators 15 05-31-2005 08:18 PM
Refill bottles ? brunoffrance Our Community 16 03-14-2004 12:10 PM
gas bottles art Our Community 4 04-10-2003 06:55 PM
LPG or propane in the bottles ? brunoffrance LP Gas, Piping, Tanks & Regulators 3 12-17-2002 04:18 PM
LP exchange bottles 83Excella LP Gas, Piping, Tanks & Regulators 5 06-19-2002 09:43 PM
