09-19-2016, 07:16 PM
Longport
, New Jersey
12 Volt Mystery - Going slightly insane
So I'm in the process of installing a small vented heater that has a tiny 12volt fan inside it - to help distribute the hot air. Draws next to nothing. Simple wiring coming out of the heater - one red wire (hot) & one black wire (ground).
When I run the heater wires direct to a 12v battery the fan runs just fine. The switch & speed control dial works just fine. When I tap into some 12v wiring in the airstream (confirmed/tested 12V with the OM meter). The fan does not run.
At first, I thought it might be a bad ground, but there's some DC lights that are tapped from the same source and they work just fine. I test the wires direct, I get 12v. I test the unit at the fan, I get 12 V.
Very weird. So I have the correct voltage from the airstream wires, but it's not running the fan. Nothing is wrong with the switch or fan, because it works when hooked direct to the battery.
I'm pretty much as frustrated as you can get with this -- It can't get any easier!!! but I still can't seem to figure out what the heck is going on.
Can anyone shed some light on the situation for me?
09-19-2016, 07:20 PM
1978 25' Tradewind
Metro Phoenix
Here's a semi-educated guess:
The fan draws a lot more current than the lights. That current draw pulls the voltage down in that circuit to the point where the fan motor won't run.
How to check: Connect the volt meter across the fan leads as you connect the fan leads to your two 12 volt wires. Iin other words, you want to measure the voltage getting to the fan as it's trying to run.
Let us know what happens.
09-19-2016, 07:34 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Hi gomotomoto, I thought I might share a go crazy problem I had when I installed a new SeeLevel water tank level sender in my Airstream. This is a 12v device that uses very little voltage or current. Maybe like your "computer fan" in your little heater. My read out was very erratic.
So the SeeLevel tech told me the instrument will not operate without a ground resistance less than 20 ohms. You might check to see if you have very low resistance to ground from the heater wire to the Airstream frame, or shell. Older Airstreams can get corrosion between the ground bolt and the frame member. Mine did, I cleaned it up, and measured 2 ohms resistance between the meter and the ground.
But it didn't solve my erratic instrument. Then SeeLevel asked about my "voltage ripple" in the DC circuits produced by an old converter. Voltage ripple can make 12 volt radios sound terrible (static) and the like. My SeeLevel instrument would work fine when I was on battery power alone. But it was erratic when I was plugged into shore power and thus using the converter output. So I purchased a new converter and my problems went away. Luckily before I went insane.
So try your heater on 12v battery power alone. Try your heater with a "pure" 12v ground wire straight to the negative of the battery, and then try your heater while plugged in using the converter output.
Chances are good none of these experiments will solve your problem. I'm just helping you along the path to insanity.
David
09-19-2016, 07:39 PM
1986 25' Sovereign
2008 F350, 6.4L diesel
, Oak Harbor, WA
Sounds like you figured out where the 12VDC is, so my guess is that you have not picked up a ground for the black wire but another 12VDC wire.
09-19-2016, 08:55 PM
1979 23' Safari
Wayland
, New York
It sounds like you know what you're doing and what to look for and from your descriptions, well I got nothing. From what you're saying seems like it should be working. It'll be interesting to see what the fix is.
09-20-2016, 05:04 AM
Longport
, New Jersey
Yes, so the question becomes: What would give a 12v reading at the heater (with OM meter) but keep the fan from running when the switch and speed control switch is confirmed to be ok?
My guess is some sort of bad ground - but if the ground was bad, wouldn't the OM meter read something other than 12v?
Running right to battery fixes the issue, I may just have to route those wires directly to battery. Kind of sucks not knowing what's going on though.
09-20-2016, 06:08 AM
1982 31' Airstream 310
champaign
A poor ground can do some really strange things to dc devices. I would persue that first. Even if logic tells you otherwise. Just to test, you could attach the + side at your heater location and then run a separate ground wire direct to the battery, see what happens.
09-20-2016, 06:21 AM
1966 22' Safari
Hilltop Lakes
I'll join the group that suspects you have an inadequate ground connection.
First, if you haven't already done so, check for corrosion at the negative terminal of your battery and also (especially) at the point where the negative battery cable connects to the shell or frame of the trailer. Clean and tight, or the whole system will be affected.
Run a temporary test connection between the ground wire on your heater fan and the metal shell or frame of the trailer. See if the fan runs in that configuration. If it runs, your problem is in the ground wiring.
Turn everything off, set your meter to read ohms, and check between the ground connection you're using and the shell/frame. Meter should read very close to zero ohms (1 or 2 max). Keep probing until you find a good ground. (Power should be off when checking resistance (ohms) or you will blow a fuse in the meter.)
Good luck.
09-20-2016, 11:06 AM
2013 30' Classic
Greenwood
, Mississippi
The thread title made me think of the Queen song I'm Going Slightly Mad.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
09-20-2016, 11:18 AM
1966 22' Safari
Hilltop Lakes
If an electrical problem doesn't drive you at least slightly crazy, you don't understand electricity at all.
09-20-2016, 01:32 PM
2012 25' FB International
Trent Woods
, North Carolina
Amen to that! I am trying to noodle through a replace my batteries with LFP's project and there are a number of wickets I am addressing.
Larry
09-20-2016, 02:24 PM
Princeton
, New Jersey
Wild thought but could there be a diode in the fan to preclude it running backwards. To test this reverse your wires where you are trying to get it to work.
Can your meter show + and - readings CD readings?
2004 Excursion 4x4
09-20-2016, 02:40 PM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
What kind of heater are you installing ??? I'm planning to do a similar project soon with a catalytic heater. It also has a small fan and is vented to the exterior made by a company in Washington. Just curious what I have to look forward to when I get into it.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
09-20-2016, 03:23 PM
1966 26' Overlander
Gridley
In your discussion of 12 volts for your heater, there is one thing you are missing, and that is amperage. Your small heater is taking much more power than you probably realize, and it is the heating coils rather than the fan that uses the power. (amperage.) There should be a tag on your heater that specifies AMPS.
A Multimeter will read volts in wiring that is large or very fine, and will give the same reading. If, however, the wire and/or connections won't carry the load, the heater won't run AND the point of restriction will rapidly heat up until a fuse blows, a circuit breaker trips, or a wire melts. None of these results are good. Hooking directly to the battery with the wires supplied with the heater covers the bases, but more research into wire size, connections, etc. is required to wire it in directly.
You should have 12 volt outlets. If you can attach the proper plug to the heater wires, this should give you an acceptable wiring set up.
09-20-2016, 04:52 PM
Airscream
1986 32.5' Airstream 325
Rio Vista
12 volt
I thought I would add to this thread.
as an electrician in the yacht service biz, ill offer some advice.
check the polarity of the supply wires, most appliances are polarized.
As Iron Man suggests wire size and overcurrent protection is a must.
for best performance ,run a dedicated circuit to your buss panel or pick up power at the input to the converter. over current,fuse/breaker should be at the head of the power source, not at the appliance end. Wire size should be determind by the current/amp rating of the device, and de rated for length.
Do not use the chassis or frame for your ground route the negative to a ground where you get your positive supply voltage.
wishing you all the best on your installation. make it safe.
09-20-2016, 05:21 PM
1973 31' Sovereign
Middletown
Can you tell us what type/brand heater and converter you are using? Also what all runs on the circuit that you are tapping into? Some converters send 12V AC to the lighting circuits. also how does the speed control work, if electronic it might be polarity or ripple sensitive. Something is not meeting the eye about this situation and more information is needed.
09-20-2016, 07:06 PM
Longport
, New Jersey
Ok, so I abandoned ship on trying to tap into other, existing 12v wiring and decided to run new wires direct to the battery (which fixes the problem). I'll chalk the original issue up to a bad or weak ground.
Next question: I'm gonna have to run a marine grade duplex wire along the drain and water lines to get it done. Anyone see any issue doing this? I had 12v wires running in my boats bilge without issues. Can't see it being a problem here.
Someone above asked which heater I bought. It's the Dickinson Marine P12000.
09-21-2016, 12:46 AM
1979 23' Safari
Wayland
, New York
Don't see any problems running the wires as described. Consider putting them in some split loom if you'll have space. Zip tie to keep them from moving around to much.
Those Dickinson Marine heaters are nice and gorgeous! Good choice!
09-21-2016, 06:04 AM
Retired
2008 30' Classic
Livingston
Assuming no thermostat to turn on or off the fan, maybe a direct connection to ground via a new wire attached to metal would help....
Tom
TVKetchum
Tom
AIR 71620
WBCCI 5809 Reg 9 Unit 155
2008 Classic 30'
2019 F250 4x4
