Hello,
I'm trying to decide whether to buy a small (15-17 L) 12V cooler to use in my Ford Ranger when not pulling my trailer, and to augment my trailer fridge when I am towing.
Right now I'm looking at a Coleman and a Koolatron. Don't know the last one. I'm interested in your opinions about their relative performance. Also, I don't know the Koolatron brand. It seems imperative that I also purchas a 120V to 12V Converter so that I can plug it in at home or on the road at a campsite with shore power. Are the 12V coolers worth the expense?
Thanks for your input.
Cindy
I bought one at a second hand store; I don't remember the brand. It came with the 120v cord and 12v cord. We really like it. I precool 9 cans of soda and then out it behind the front seat. When not travelling, it sits on my workbench so I can grab a can of cold soda when working in the yard.
When at a campsite, I put it on top of the fridge and plug it into 120v for precooling sodas. If we go on a day trip, we take it with sandwiches and the like.
They are all based on Peltier junctions and work essentially the same. The one I have can be found new at HD for about $45.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
We have the Coleman. It's now a necessity. We keep it in out Honda Odyssey for cold stuff from the store. We also use it when taking stuff to the RV in storage. It will keep stuff cold. It is not a freezer. I also recommend getting the 120v adapter.
We also have a Coleman. We use it all the time in the Gladiator. When we go shopping, we don't have to rush home to put perishables in the fridge, we can finish up on errands. We can also travel further with perishables
BTW, what is a Peltier Junction?
Stan and the Lou
Together Forever
BTW, that's MaryLou
is what all of these coolers use to move heat in or out (most can be used as heaters as well as coolers).
A Peltier junction is a flat semiconductor module that moves heat from one side to the other when DC current is applied. It also will generate current if there is a temperature differential between the two sides, but this is of no interest here.
In one of these coolers, there is usually a heat sink and a fan to cool the external (typically hot) side of the junction. On the inner surface of the cooler, there is usually aluminum plate that is screwed to the cold side with thermal paste between. Sometimes, on the larger units, there is a second heat sink and fan inside.
It is a great way to run a cooler with no moving parts or flames.
John W. Irwin
I always wondered it those things really worked well!
Eric
Originally posted by Tripp Some of the off road guys use a cooler made by ARB. As I understand it, it'll FREEZE your food if you want it to! Big dollars though.
I see them advertised all the time in the various truck mags, just can't remember the US vendor.
Tripp
Yeah those ARB units are EXPENSIVE! One of the guys in my 4x4 club has one. We call him the Ice cream man. He usualy has it packed full of Ice cream and gives it out when we have lunch. They work and they will freeze. They can maintain freezing inside in the mid 90's outside temp. Just need to keep them in the shade.
My local 4x4 shop carries them and I think four wheel performance also carries them.
On the other units:
It's my understanding that they can make about a 40 degree drop in temp. So if the temp outside the unit is 90 they can get down to 50 inside. If your running them in the car while you have the A/C on they do pretty good. Sitting in the sun on a 95deg day they may only get items down to 60 degrees.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
We have the 35qt Igloo heat/cool version and love it. We were planning to buy one new when we found a practically new one at our subdivision garage sale last fall (paid $25, but it was missing the shelves). Ordered shelves from Igloo along with a 120V converter and a device that prevents the cooler from draining the car battery (ie using it on 12V without the motor running). We love the big size and the fact that we can use it as a chest or upright unit (normally we use it as a chest to mimimize the loss of the cold air when opening. We also found a trick to using it for frozen foods. Cool it down for a day or so empty(in the cool of the house), then buy a slab of dry ice (5lbs) and put it in the unit, then add your frozen foods (have kept foods frozen HARD for way over a week this way). Without the dry ice trick, you will find it is, at best, a cooler during the summer. Ours is an indepensible part of our A/S rig as we also use it for beer, pop and wine for those week end rallies and parties.
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
President Heart of Texas Camping Unit
WBCCI # 7548
"It will also generate current if there is a temperature differential between the two sides"
Is that why when I remove the plug from AC, the charge LED will remain on and the squirrel cage keeps turning? I found it pretty curious. I had to take off the cover to see what was under there. The Coleman I have has the heat sinks and fan both in and outside of the unit.
59Toaster, you are right about that 40 degree drop. Even with that, it still has a use for the sodas and beer, stuff that won't spoil from a little warmth. I wouldn't trust it with meat in it for two days in the middle of August, though.
Stan and the Lou
Together Forever
BTW, that's MaryLou
Hmmmm, now you all got me wondering.........I bought one of those $100 mini fridges for my shop. I'll have to check the current draw on the compressor, to see if it is possible and practical to run the little bugger on the 400 watt Vector inverter.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
We had the 35 qt. Igloo. . .it quit working during the first use. I had to send it to Igloo (at my cost-UPS $12.00) for warranty repair. When returned, it never got anything any colder than a conventional ice chest with 10 lbs of ice in it. I had all the cords and adapters; and the "battery saver" had a disclaimer that it wouldn't work with some auto models, but didn't specify which ones. It ran my battery down overnight in my 1999 Ford E-250 van during a trip. It wasn't worth the hassle so I quit using the cooler and sold the whole lot for $35.00 in a garage sale to help cut my loss! Hope other folk have had better luck!
Two Hams in a Can, and Madison the Cocker Spaniel in our 1998 30 ft. Excella, Hensley Arrow Hitch, 2001 Red Silverado 2500HD Extended Cab, 8.1L Vortec, Allison Transmission
