01-26-2010, 04:35 PM
1960 24' Tradewind
flat rock
, Michigan
wheels for 1960 tradewind
Can any one tell me what kind of wheels they used for 1960 tradewinds. mine are rusted out from sitting the past 30 years and i need to find new ones thanks jack
01-26-2010, 05:42 PM
Corona
15 inch wheels, 6 inches wide, zero offset, 6 lug, minimum 2600 pound rating.
01-26-2010, 06:33 PM
Baltimore
, Maryland
I own a 59 tradewind and it is on 14.5 " rims. Any chance a 60 is the same?
01-26-2010, 06:41 PM
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
Hi Jack ~
Welcome to the Early TradeWind club. There are a bunch of us on the forums and you'll get all the answers to your questions. Glad you joined us. I just sent you a PM )private message) about your TradeWind so I can add your info to my registry.
TradeWind's ROCK!!
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
01-26-2010, 07:54 PM
1960 24' Tradewind
flat rock
, Michigan
mine has 14.5 rims i am looking for what type rims they used because i need to get new ones
01-26-2010, 08:06 PM
1960 24' Tradewind
flat rock
, Michigan
did u get my message
01-26-2010, 09:13 PM
Corona
The 14.5 wheels were basically mobile home wheels, that's not really around any more.
You can safely use 15 inch wheels, just make sure that they are rated for at least 2600 pounds, per wheel.
01-26-2010, 10:19 PM
1959 24' Tradewind
Phoenix
I did and thank you. I sent you one back via an email.
FF
01-27-2010, 02:38 AM
Baltimore
, Maryland
When I recoved this trailer from West Virginia I took 15" six hole from one of the 54 safari along with me. The wheels could barely fit in the wheel well and the rim would not fit onto the hub. I towed her home on what looked to be original tires. Those tires are old but look to almost perfect. No checking or dry rot at all. They are 12 ply tires. My Tradewind is actually the nicest towing trailer I have ever pulled.
01-27-2010, 07:41 AM
1967 22' Safari
1960 Caravel
Edmonds
For what it's worth my 60 Caravel had 15" rims on it. Get the tape measure out and save yourself the headache of getting the wrong wheel. FAQ's
Keep in mind that standardization was not the name of the game with Airstream back then.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
