Old 09-23-2013, 05:28 PM   #1
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
wheel well sealing
Does anyone know what was used to seal the wheel wells with? Or what I should use to reseal them with? New axles should be in soon and I want to reseal and paint everything before I put them on.
thehandyman is offline   Reply With Quote
Old 09-23-2013, 07:01 PM   #2
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
I had first thought about rhino liner then decided rubberized undercoat.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 08-02-2017, 02:12 PM   #3
Overdog64
1964 26' Overlander
Collingwood , Ontario
I'm thinking about the rubberized as well(64 overlander). Does anyone know what kind of metal it is? does it need a primer? Rm what product did you use? and has it endured? (could have said lasted but thought this would make me look smarter)
Deanmaher is offline   Reply With Quote
Old 08-02-2017, 02:46 PM   #4
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
The wheel wells on my 67 were galvanized steel.
The new ones I had made are galvanized as well. I washed mine with "marine clean" then used "metal prep" on them which etched the metal so the paint or... has something to grab on to.
I used rattle can rubber undercoat. Not sure how it will hold up. Have not had the trailer out yet.
Both prep products are available at Vintage Trailer Supply.
Dingo Girl is offline   Reply With Quote
Old 08-10-2017, 04:50 PM   #5
Overdog64
1964 26' Overlander
Thanks Dingo girl that info really helped
