Old 12-25-2008, 09:30 AM   #15
dwinick's Avatar
1958 22' Flying Cloud
1948 16' Wee Wind
Ada , Michigan
you can find exact repro wheelwells here:
finest vintage and custom Airstream trailers
A politician is a man who will double cross that bridge when he comes to it.
Oscar Levant
dwinick is offline   Reply With Quote
Old 02-02-2013, 04:50 PM   #16
jerbear315's Avatar
1966 17' Caravel
College Station , Texas
Images: 22
Has anyone managed to find a pre fabricated wheel well. Some of us just do not have the time or patience to be fabricating our own!
Looking for replacements for 66' Caravel. FLIMSY plastic.
Dang, I just saw the post above mine. Finally, I have found a source! But dang expensive.
jerbear315 is offline   Reply With Quote
Old 02-03-2013, 09:26 AM   #17
mapleton , Utah
try a local heating/ac shop. I had mine remade with heavier galvanized last year for about $150 for the pair. very good quality.
rumrunner is offline   Reply With Quote
Old 02-04-2013, 12:06 AM   #18
BB 55 Bubble's Avatar
1955 16' Bubble
Bend , Oregon
I did get mine at a local HVAC shop. It was the need of a Pittsburg seam or a Z seam to be effective. The only problem I ran into is the flange the is used to attach the well to the trailer shell was a considerable smaller side than the original. It worked out just fine and the buck riveting was not a problem. Tight but still functional.
Ever notice an Airstream resembles a piggy bank
BB 55 Bubble is offline   Reply With Quote
Old 08-27-2017, 08:48 PM   #19
Rockton , Illinois
Any chance you can hook me up on how to make a pair of
wheel wells for a dual axle 1969 Sovereign?
The ones in it are plastic and are beat up causing big time leakage ):
Your my saving grace.
jbknowso is offline   Reply With Quote
« wheel well sealing | Top | - »
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Wheel Chocks pjtaia On The Road... 13 10-28-2005 02:27 PM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
Brakes replacement tip Charles Q Treichel Brakes & Brake Controllers 14 09-29-2002 05:23 AM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
