06-06-2014, 07:11 PM
1975 31' Sovereign
cary
, North Carolina
Wheel well, outer replacement. 1975 31'
Ok, so the PO had a bad tire blowout, and cut a hole in the curbside wheel well the length of a man to put garden hose tubing on a copper line, please bear in mind the entire AS has been redone in pex.
I tore out the wheel well , or what was left of it, thinking it was going to be simple to replace. well, from what i can tell, its underneath the sub floor. Is their any tricks i can do to re-attach the donor wheel well in a proper manor so that it serves its purpose? i have another one from a donor frame that's in really good condition.
any takers?
06-06-2014, 08:14 PM
1976 27' Overlander
Tampa
Interesting... my '76 wheel well is not under the subfloor. It fits into a c-channel type extrusion that slips over the subfloor the same way as the c-channel around the sides. Then the wheel well sets on top of it- in its' own little channel. Have to have the interior out to replace, so I've wondered what I would do if I have a blow out that damages it once I have this thing all back together.... Guess I'll have to buy tires more often than I'd like as insurance.
06-06-2014, 09:14 PM
1975 31' Sovereign
cary
, North Carolina
or get antiqe'ers insurance. Tire blow outs suck, this one was so bad it destroyed the subfloor the water heater was on and i had to replace that . I also found out that if you go lower on steel rims in terms of ply, you can never go up again, as you will bend/crack the rims. however this doesn't apply to the aluminium forged rims.
06-06-2014, 09:15 PM
1975 31' Sovereign
cary
, North Carolina
its also quite possible the PO or shop that worked on this never replaced the channels correctly, if thats the case, i have channel left, and ill just cut and fab it back, can ou take some pictures of yours and post if you would be so kind?
06-06-2014, 09:34 PM
1976 27' Overlander
Tampa
Yes, but out of town this week. Will post Friday... remind me if II forget
06-08-2014, 06:49 AM
1973 21' Globetrotter
Houston
The wheel well on my 73 was installed underneath the subfloor as you describe. As I recall, it even gets sandwiched between the floor and the fore and aft outriggers as well. It would be tough to replace "correctly" without major surgery. I supposes you could cut the flange and about 5/8"off the bottom of your new wheel well and then seat it on top of the old one, above the floor, for something of a doubling or nesting effect. You could seal it up with vulkem and buck a few rivets in there to keep it together.
06-08-2014, 10:40 PM
1975 31' Sovereign
cary
, North Carolina
ughh... its looking like major surgery then to do it right..
