Old 09-25-2010, 08:41 PM   #1
Mike&Ali's Avatar
1964 22' Safari
Dayton , Ohio
What are wheel wells made of?
Doing some repair work on my wheel wells (64 Safari). It appears that they are made of galvanized steel. Is this accurate? If so, can you use aluminum rivots to make repairs?
Mike&Ali is offline   Reply With Quote
Old 09-25-2010, 10:05 PM   #2
Sure, if you want to. Probably won't corrode for maybe 40 years.
Old 09-26-2010, 02:51 AM   #3
Baltimore , Maryland
These were bent to replace the wheel wells on a 64 sovereign...
Old 09-29-2010, 02:39 PM   #4
Mike&Ali's Avatar
1964 22' Safari
Dayton , Ohio
So the wheel wells are galvanized steel - got it. I waited to replace them until I got my new axle on. By doing this, I could not slide the "lips" under the floor. So I bent some new galvanized and slid it under the plywood floor and then rivoted it to the original wheel wells. Sanded the rust off, primed them, and then used the underbody coating. Lots of Tempro 636 in the corners to prevent water from getting in. Hope it works.
Old 09-29-2010, 05:23 PM   #5
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
Sticking with steel is a good idea, I considered aluminum but bailed when I reconsidered that the wheel wells are there for protection from blow outs and rock attacks etc as well as water.
truckasaurus is offline   Reply With Quote
wheel well
Where to buy wheel wells qc1500 Wheel Wells 14 09-22-2010 06:25 AM
wheel wells berickn Wheel Wells 2 07-06-2010 11:53 PM
About my wheel wells? chuckmac All Argosy Trailers 4 05-22-2009 08:23 AM
Leaky wheel wells TomW Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-25-2005 01:00 PM
Plastic Wheel Wells Dennis Interior Restoration Forum 14 01-17-2003 12:05 AM
