Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Wheel Wells
Old 04-05-2006, 10:10 AM   #15
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
I think you are going to need "more truck" in towing, even with a vintage Bambi. When we first got our GlobeTrotter, which is the next size up from a Bambi, we had a Jeep Cherokee which was rated for 5500 lbs towing. Our GT weighs in at about 4200lbs fully loaded and at Colorado elevations, we struggled! So much so, we were almost ready to throw in the towel. The Jeep overheated and gasped for air at even the slightest elevation climb. We now have a Yukon and towing is much more enjoyable (and safer)...by far!
Your going to need much more power than you would at sea level...
Regardless, we'd love to have you join us at Creede and beyond, hope you get things worked out!
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
InsideOut is online now   Reply With Quote
Old 04-05-2006, 12:31 PM   #16
wagongirl
wagongirl's Avatar
Profile:  1967 20' Globetrotter
Redford , Michigan
Images: 11
Originally Posted by baldwicm
3) an easy, rivited, creative patch "arching" over the wheel (maybe streetside, too so it would match?
Thanks so much.
http://www.vintageairstream.com/Myrtle/axle.html
here is a great article on a very similar repair, up to you if it is within your skills, budget to do it.
Mr. Wagongirl
wagongirl is offline   Reply With Quote
Old 04-06-2006, 12:45 PM   #17
2airishuman
2airishuman's Avatar
Profile:
Originally Posted by clancy_boy
I purchased a "scare light" or white porch light that was 4.5 inches around and used a hole saw to drill out the offending dent. Then wired it in and use it whenever I go camping and arrive at night to make the hookups in the dark. Works for me.
clancy boy.....
that is a brilliant mod for a blemish.
have you got a photo to post?
what a great idea.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 04-06-2006, 02:19 PM   #18
AYRSTRM2
AYRSTRM2's Avatar
Profile:  1966 22' Safari
Armada , Michigan
Not to scare anyone here, but if it's a "tear", then you might want to investigate if it has rear or front end separation. That can be an indication of such a problem.
John
AYRSTRM2 is offline   Reply With Quote
Old 04-06-2006, 02:21 PM   #19
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Yes And No
Originally Posted by 2airishuman
clancy boy.....
what a great idea.
cheers
2air'
Yes, I have a photo, but No - I don't have one with me. I can send you one in 3 weeks when I get home.
I bought the Grote scare light from Vintage Airstreams for I think $29 and change. They have the same light - chrome trim and clear lense - at Flying J truck stop for $9.99. Does not say Grote but the lense casting and bezel are exactly the same (Made in Taiwan???).
I need to post a photo, because when I did the repair, I was botherd by the dent and possible panel replacement. It look factory and the placement - 8 inches to the right of the service access and 4 inches high centers it on the panel. I installed one in the panel to the ower right side of the door to flood the steps at night. Look original.
OK, none of this makes sense without photos, I will post in a few weeks - sorry - the job has me deployed right now, I'd rather be home working on the Caravel and not reading your threads but actually doing some of the stuff you guys are doing. I envy alot of ya'lls work.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 04-06-2006, 07:39 PM   #20
geosouth
geosouth's Avatar
Profile:  2001 19' Bambi
Running Springs , California
Cynthia-
Juel's repsonse pretty much negates the no deal issue regarding title, if of course, your seller is cooperative. A 4' or 5" tear would be at least several hundred dollars, if not a grand to repair 'right' at a shop. Except you got all of these terrific responses regarding patches. However, you may want to use this tear as a bargaining 'chit'. I had a pretty good dent on the rear cone of a less than vintage Bambi and it was worth $1,000.00 off of the price we agreed on. On the other hand vintage Bambi's are hard to come by...
geosouth is offline   Reply With Quote
Rolite or Nuvite? What did you decide? airstreamcaravel Cleaning, Stripping & Polishing 31 10-18-2002 07:14 AM
Thanks(Help Decide) SAM Our Community 3 09-14-2002 05:26 PM
Help decide ? SAM Our Community 4 08-01-2002 07:12 AM
And you think you got a deal... BobbyW Our Community 21 06-05-2002 07:54 PM
