Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Wheel Wells
Old 06-24-2008, 09:37 PM   #1
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Street side rear outrigger
I just noticed that the street side rear outrigger has rusted through in a couple places on the lower edges where the lower aluminum panel rivets in place. The rivet nearest the frame has pulled through and the outrigger needs to be replaced. If I removed the rear wheel/tire, drilled out the second rivet, cut the outrigger off with a reciprocating saw and ground it down to the frame, could it be towed a couple miles (tire back on) to a welder for the final weld of a new outrigger. Any other suggestions?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 06-25-2008, 12:21 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Sure can.
Just take it easy on the way to the welders shop.
Or, you can hire a mobile welder, but I am sure the cost would be prohibitive.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 07-20-2008, 02:01 PM   #3
davidz71
davidz71's Avatar
Slight problem
Well, as to be expected, nothing is as easy as it looks. Most of the outrigger has been cut away and then I realized that two screws or bolts are screwed down from the floor through the top of the outrigger. I couldn't be so easy for me to take the platform off my bed and then unscrew them from topside. No, they are either just under the inner fender well lip or just under the water heater. Now, what do I do? Can I just grind them off from the bottom and let the floor rest on top of the new outrigger with a layer of caulk in between? On top of that, it started raining cats and dogs so I had to pick up my equipment and run for the garage.
Craig
AIR #0078
3.73 rear end
Old 07-20-2008, 06:44 PM   #4
davidz71
davidz71's Avatar
I've successfully cut off two of the bolts and then cut perpendicular to the top piece of metal and through the center of the bolt. I've removed about 8" of the outrigger from the frame side toward the aluminum skin. I have found one more screw/bolt near the edge of the outrigger and am having problems getting into that area to get the last 2" of outrigger. I guess I will just keep cutting until it comes loose. Next will be the grinding wheel to the frame and wire brush toward the back in order to zinc phosphate the frame and apply POR away from the weld. I'll also try to treat the outrigger away from the weld also and then finish it up at the weld site. I'm not sure how I will secure the floor to the top of the outrigger.
Craig
AIR #0078
3.73 rear end
Old 08-09-2008, 05:07 PM   #5
davidz71
davidz71's Avatar
Finished
I had the outrigger welded to the frame last Wednesday, cleaned the area up and zinc phosphated the weld area again prior to the final application of POR15 then Chassis Black topcoat which I did on Thursday and Friday. Friday evening I used PL polyurethane black to seal the areas where water could be splashed past the outrigger. Today I masked those areas off to allow the rubber to continue curing and then hit the outrigger surface with rubber undercoating to prevent any rock chipping of the POR surfaced outrigger. The tire is now back on and I am ready to rock and roll.
Craig
AIR #0078
3.73 rear end
'68 Globetrotter with a street side booth? gypsy man Cabinets, Counter Tops & Furnishings 0 11-08-2007 06:38 PM
Fabrication of Hehr Street Side Window rek Windows & Screens 0 05-04-2007 01:12 PM
Street Side Gaucho Plans ColdEspresso 1978 Caravanner 0 11-22-2006 10:39 AM
What is the small white thing on the street side housebg Exterior Restoration Forum 4 07-26-2006 10:36 PM
Street side window broken on '71 sovereign DaisyandDave Windows & Screens 2 03-28-2006 07:23 PM
