08-07-2016, 10:04 PM
1962 22' Safari
Granite bay
Replacement rim and tires
This is my first day on the forum and I apologize now if I am asking a question that has already been covered. I have been trying to search previous threads for my answer but now I think it may be easier just to ask. Could you guide me in the correct path or give me an answer.
I have a 1962 Safari 22' that I would like to replace the rims and tires. I still want to keep the look vintage with the moon caps but I am not a fan of the two piece original rims. Does anyone have any recommendations on the size of the rims and tires I should upgrade to? I was thinking of going with a 15" rim so that I would have more option and more availability with tire selection. Thanks
08-09-2016, 02:14 PM
1973 21' Globetrotter
Houston
Welcome to the Forums!
Yes, you definitely want to be rid of the split rims. A 15" rim should fit just fine. Because you have a single axle, in order to get the tire weight capacity you need, you will probably still be limited with the tires you can buy, so make sure you do the math before heading to the tire store.
A good way to search the Forums is to open a new browser window and do a gooogle search including terms like "airforums split rim" and you will probably learn more about your rims and what other people with them have done.
good luck!
08-09-2016, 03:28 PM
Mantua
, Ohio
Etrailer gas all kinds of wheels. I bought my 16 inchers for 65 bucks a piece. You can put moons on them.
08-09-2016, 04:01 PM
1960 33' Custom
Athens
, Georgia
Hey. Not to hijack but which moons go on the 16" rims
08-09-2016, 05:23 PM
Mantua
, Ohio
Moons on 15 inchers, I was referring to the op, not the wheels I bought. Sorry
08-12-2016, 03:06 PM
1958 22' Caravanner
Plattsmouth
, Nebraska
My 1958 Caravanner had 14.5" with 5.5" center lug holes. I went 15 x 6 on 5.5" centers zero offset. and 205/75/15 LRC 6 ply nylon-rayon steel belted bias tires. Can carry 1820 # per tire. Run w/ 40 psi to maximize contact patch to 70 mph (USA) but air to 50 psi max when running 90 mph on German Autobahns. Good fit but must frame jack pretty high to slip on easily. Diameter is good. No tire squirm. Gutted Caravanner now only 2,180# as carry most camping type stuff in Escalade EXT.. Changed my suspension to independent twin air bag air ride w/11" clear underbelly lift clearance . Very very sure footed.
08-12-2016, 10:51 PM
1962 22' Safari
Granite bay
Thank you all for the feedback on the wheels and tires I should look for.
08-12-2016, 11:08 PM
1962 22' Safari
Granite bay
Thanks for the tip
08-14-2016, 06:16 PM
1975 Argosy 24
Lakeview
, Oregon
Another Wheel Upgrade Question
First Timer in SE Oregon...
I picked up my first Argosy (1975 24T) a few weeks back which looked to have the original steel rims and 700X15 Bias tires. Last week I picked up a set of 6 bolt 15" HWT aluminum rims with tires from a super nice airforum member up in Redmond who was upgrading to 16" wheels/tires on his 2010 30' Classic. The rims match the bolt pattern and the tires fit perfectly, but my original lug bolts are too big (13/16") to fit a socket inside the bore: A 3/4" socket will fit, but in reading some of the posts on this site, the advice is to upgrade to lug studs and nuts. Question: Does anyone know of an off-the-shelf kit or the specific studs (including length) and nuts I need so the acorn nuts will fit correctly? It seems like a lot of folks make this upgrade, and they sure do look great on the Argosy. Thanks in advance for your help! Jody Rae
