Old 04-27-2015, 04:59 PM   #1
2018 25' Flying Cloud
Mission , Texas
Repair after a blowout
Blow out on left side - (single axle) did not take out the wiring or the gas line, but I would like to repair the pan to keep mud & critters from getting into the space between the pan & the flooring...Any suggestions other than an RV dealer?
ghamr is offline   Reply With Quote
Old 04-27-2015, 05:57 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Personally I would make the journey to JacksonCenter. The work will be done right the first time.
MICHAEL
Need to Repair Damage caused by Tire Blowout Re-Pete Belly Pans & Banana Wraps 30 05-20-2015 02:02 PM
Fridge stopped working after tire blowout Smoky On The Road... 26 04-20-2011 05:49 AM
2001 Bambi tire blowout rcaldwel Tires 21 03-22-2006 04:19 PM
Tire blowout damage Les Staley Tires 6 05-06-2005 11:29 PM
Blowout John Brimer Airstream Motorhome Forums 3 08-27-2002 05:15 PM
