Old 01-28-2016, 05:27 AM   #1
Portland , Oregon
Material Choice for Wheel Wells
I am off to a sheet metal fab shop to get some frame crossmember spent.
Still need to fab some wheel wells.
1952 Silver Streak Clipper. Galvanized or Alu? Thickness?
Original in mineClick image for larger version
Are not a good pattern to copy. Sorry already removed the plywood.
Please help. Moving towards the finish of this project...
bikeukeguy is offline   Reply With Quote
Old 01-28-2016, 06:51 PM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Galvanize will be more durable. I made mine out of 22 gauge sheet metal and then painted with bedliner. Mine are tandem wheel and are pretty little.
Matt
rugjenkins is online now   Reply With Quote
Old 01-28-2016, 06:52 PM   #3
rugjenkins's Avatar
1975 Argosy 28
Spell check strikes again! I meant to say they are lite
Matt
Old 11-28-2016, 12:37 PM   #4
1958 18' "Footer"
1957 26' Overlander
Wentworth , South Dakota
I'm getting ready to replace my wheel wells. Since I'm doing an off frame restoration, I am looking at the width of the wheel wells and noticed that the extensions making up the wheel well are 14 3/4 inch from the frame. When I put the old wheel wells over the tires on the extension, I can see about 1 1/2 inches of galvanized metal stick out from the top of the trailer frame. So that makes the inner wall of the wheel well closer to the tire. Can not figure why, other than it does give you 3 inches inside, but both wheel wells are under cabinets/beds/ so losing that space inside doesn't bother me.
See any reason not to make them wider?
brenderay is offline   Reply With Quote
Old 11-28-2016, 12:49 PM   #5
Images: 59
The extra space at the top inside will be good if you have wider tire than the original. It will be easier to wrestle the wheel off the hub.
Especially true if your original tires are 14.5" trailer tires and you want to switch to radials which are wider.
New tanks around wheel wells? truckasaurus Waste Systems, Tanks & Totes 0 10-12-2008 05:52 PM
sealing seams in the wheel wells.. safari25-05 Wheel Wells 6 01-16-2007 03:38 PM
Wheel wells question cameront120 Roof 4 06-11-2006 10:41 PM
Leaky wheel wells TomW Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-25-2005 01:00 PM
Plastic Wheel Wells Dennis Interior Restoration Forum 14 01-17-2003 12:05 AM
