Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Wheel Wells
Old 10-19-2009, 01:18 PM   #1
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
Fixing tread separation damage
This is not fun, especially if it happens when you're far from home. I should have replaced the tires on the Overlander, since it had been in "dry dock" for about 4 years, but they looked so good...
The tire tread failed just outside Idaho Falls. The core still held pressure, so getting to town at low speed didn't require putting on the spare. Commercial Tires didn't have any bias ply 7.00/15s in stock, so they suggested radial 225/75R15 as a close replacement. They even mounted one and did a trial fit, just to make sure. I couldn't tell the difference, so I replaced all 4.
When the tread comes off, you get two kinds of damage. First, the skin is not closely trimmed to the front outrigger, so the tread beats it down and generally cracks the skin for several inches. This is cosmetic damage. The other damage is the inner plastic whell well liner get cracked and usually gets torn away from the shell, allowing pink fiberglass to hang down and allowing the liner to rub on the tire(s).
Name:	IMG_0259 field repair-s.jpg
ID:	89333 Click image for larger version
Name:	IMG_0279 trim edge-s.jpg
After getting new tires, the first order of busines was to stop the loss of insulation and get the liner off the tires. The spring clamps in the above photo worked fine--even drove about 40 miles using only the clamps (4 of them) to hold the plaster liner to the shell.
To fix the skin I cut away most of the bent aluminum and drilled a few stress relief holes where the cracks seemed to be headed. The next step was cutting a patch and a length of 3/4" L-extrusion to hold the edge of the patch firmly against the outrigger. The vertical web of the extrusion was placed between the existing rub panel and the outrigger, so that there is no edge for any future separated tread to hit/grab.
Name:	IMG_0288 trimmed skin-s.jpg
Name:	IMG_0307 finished patch-s.jpg
ID:	89336 Click image for larger version
Name:	IMG_0297 rub plate-s.jpg
Trimming the banana skin back to the edge of the outrigger required the skin at the front of the wheel well to be trimmed and re-faired. Make sure you get the trim back on. Otherwise, you have a sharp edge that will be a hazard the next time the wheels are removed.
Name:	IMG_0298 finished skin-s.jpg
ID:	89339 Click image for larger version
Name:	IMG_0287 outer edge-s.jpg
The outer end of the L-extrusion needed a small amount of curve to fit the outrigger (thanks, shrinker tool). A little additional persusion from a plastic mallet got it fitting tight. You can't see the repair unless you get your eye level down below the axle mounting plate.
Reattaching the liner to the skin is a big problem. The liner doesn't have a lot of extra margin along the edge to allow easily riveting it back in place. In addition, if you don't have rivet washers or some long piece of thin aluminum to act as backing, the rivets probably won't hold. Fortunately there was a metal dealer near the tire shop who had 12' x 1-1/2" x 1/8 pieces of aluminum in stock and Lowe's had a box of LONG, I should say VERY LONG, pop rivets. You need a rivet with almost 1/2" grip to hold the skin, plastic, and backing. I installed the inside "rail" as an emergency repair and waited to do the cracks until I was home and had the shop handy.
I don't know if this is a good repair or not. Without access to the back of the plastic, there is no way to put a washer on the rivets. Will they hold and will the plastic tolerate them? And will the Vulkem provide a seal? Don't know, only time will tell.
Name:	IMG_0290 cleco-s.jpg
ID:	89340 Click image for larger version
Name:	IMG_0295 curved edge-s.jpg
Forming the patches takes a bit of time if the cracks require patching up in the curve. This is particularly true if the crack is in the front radius, where a compound curve is required. All I can say is, you have to shrink the edge of the metal for the new patch before you put the bend in it. How much shrinking (thanks again, shrinker tool) and how much bending is pure esitimation, but I managed to luck out on the first try.
Name:	IMG_0296 installed plates-s.jpg
What's the bottom line, here? Check your wheel wells for two things. First, see if your banana skin is trimmed so that a tread can't rip it. Second, the liner cracks probably exist, even if you haven't had a tread separation. Run your hand along the liners to check them. Most of the cracks (all of the ones I've experienced) are in the outboard wall of the liners, so you can easily feel along that surface to find them.
Zep
Current 6-word memoir: Airstreams and Kayaks, a perfect match.
www.mindseyephoto.com www.airstreamdoctor.com www.pygmykayaker.com
Old 10-19-2009, 01:51 PM   #2
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
I had the same issue with a bias tire that was very old a few years ago. I noticed the spray of rubber from the wheel well and stopped right away. The only damage I had was the trim piece in front of the wheel has separated from the well. A couple of rivets later it was as good as new.
I lucked out on the tire we noticed when we were with you two weeks a go. I replaced the tire in Fort Collins with another brand and then replaced it with the same brand (Tow master) when I returned home. It seems tires are regional. What they could not find in any Colorado Discount Tire was in stock at my Discount Tire store in Phoenix.
Here is a picture of the old bad tire and another of Roger helping change the more recent bad tire.
ID:	89346   Click image for larger version
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 10-19-2009, 03:27 PM   #3
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1995 21' Sovereign
1947 22' Liner
Valley View , Texas
Images: 42
Ready for the road
Roger....looks like you were ready for anything on the road with you tool boxes full. I feel funny having my truck bed tool box loaded with tools and materials for the unexpected. I hope I never have to use the hack saw and metel snips. Duct tape? Is there any question about its use?
As usual...a great job.
Goodyear Marathon tread separation ... and our solution RossFam05BH Tires 219 09-17-2009 03:02 PM
Dual Marathon Tread Separation - AGAIN gklott Tires 12 10-17-2008 11:14 AM
Maxxis Tire Tread Separation Al - K4GLU Tires 44 07-26-2008 09:10 PM
Bathroom water damage? Worth fixing? Curtis-79MH 1966-68 Caravel 3 09-12-2006 11:55 AM
Underside damage from truck tire tread gklott 2004 Classic 1 06-11-2004 09:15 PM
