Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Wheel Wells
Old 02-11-2003, 08:56 PM   #1
Chas's Avatar
Profile:  Austin , Texas
Images: 22
cracked wheelwells
Has anyone found a good product to seal up cracks in their plastic wheelwells? My Overlander has a couple of 3 inch cracks, probably caused by unbalanced running gear but that is a entirely different discussion!! It needs to be something that will stick to the plastic and be able to flex a bit. I was thinking maybe some Plumber's Goop, a horribly sticky, flexible almost non-removable substance. Any other ideas?
Chas
Chas is offline   Reply With Quote
Old 02-11-2003, 09:42 PM   #2
Creampuff
Creampuff's Avatar
Profile:  1957 22' Flying Cloud
Malibu Lake , California
Images: 60
Chas
There is a latex caulk called "Big Stretch"which probably would work.It comes in a standard size cartridge at better building supply stores and you can get a color close to the original plastic.It smoothes out well when you let it set a couple of minutes and work it with a sakiva-moistened thumb.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 02-11-2003, 09:53 PM   #3
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Both sides?
Chas, I was thinking that maybe you'd want to seal some cut out innertube to the inside of the wheelwell with the goop to ensure rain doesn't come up through the crack? I know someone else was repairing their wheelwell, but I can't remember the thread.
Marc
Old 02-12-2003, 10:59 AM   #4
Commercial Vendor
Profile:  Corona , California
CRACKED WHEEL WELL REPAIR
Repairing cracked plastic or metal wheel wells is done very easily.
Remove all the dirt from around the crack. Add an aluminium plate that's about 2 inches wider and longer than the crack. Drill all the holes.
Remove the plate and place a generous amount of "vulkem" sealer on the back side of the plate. Reinstall the plate with aluminum pop rivets, using #48 pops.
Add more vulkem sealer, to the completed installation, both over the complete plate, and, past the edges of the aluminum by at least an inch or two. Again, use a generous amount of vulkem.
Let the vulkem set up for a day or two.
Spray a generous amount of "underseal" on and past the vulkem.
The repair is now complete.
However, get the running gear properly balanced, so that it doesn't happen again.
Also while your at it, check the interior wheel well. You may find that it is also cracked and/or separated from the wall. It can be repaired the same way as the exterior wheel well.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-12-2003, 11:30 AM   #5
Chas's Avatar
Images: 22
Thanks Andy,
It may be trcky to get the aluminum plates to match the curvature of the places I got cracked but agree it is needed to give it more strength. I found a shop here that will balance everything on the trailer, I guess they have the tire spinner and a strobelite? Are the aluminum wheels less problematic when it come to balancing issues? I have the original mags on mine.
Chas
Old 02-12-2003, 11:51 AM   #6
Commercial Vendor
Charles.
Mag or aluminum wheels, by their very nature, are indeed, much closer to being balanced.
However, they are not in fact, "in balance."
inlandrv.com
airstreamparts.com
airstreamcandy.com
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-18-2003, 04:35 PM   #7
Chas's Avatar
Images: 22
Here is a patch on one of my wheelwells.
Chas
Old 02-18-2003, 05:05 PM   #8
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
Thumbs up looks good!
chas that should seal it well!
nice work.
john
Old 02-18-2003, 05:15 PM   #9
Profile:
Chas,
Good job!!
Sounds like you're almost road ready !!!
John
John is offline   Reply With Quote
Old 06-18-2003, 11:10 AM   #10
Profile:  1972 27' Overlander
Saline , Michigan
I have a similar question about wheel wells,
After replacing old tires on my 72 27' international with Goodyear trailer 225's my door side wheel well has worn thru by the wheel rubbing against it.
The other side is tight too but does not rub.
It looks like the side that has rubbed is bowed out a bit while the other side is not.
Any suggestions on resolving.
loechli is offline   Reply With Quote
Old 12-05-2006, 02:05 PM   #11
Profile:  1971 27' Overlander
Baton Rouge , Louisiana
Same problem
I have a 71 overlander with the same condition. The plastic seems to have warped and cracked and is now affecting the shape of the wheelopening/body. I'm going to try Andy's repair and install some heavier material to stiffen the edges.
robertsonmd is offline   Reply With Quote
Old 12-05-2006, 06:34 PM   #12
Commercial Vendor
Some of the early 70's trailers had a frame that was pushed to one side, because of the method of construction.
Adding an oversize tire will usually result in rubbing a hole in one of the wheel wells.
Your lucky, as that rubbing tire could also set the plastic on fire.
Next item to check is the axles. If the axles are shot, the tires can wear holes in the top of the wheel wells, something not easily seem.
Exterior wheel wheels can easily be repaired by plating the hole with aluminum that has been pop riveted in place, followed by several coats of underseal on top of it.
It is not wise to increase the width of the tires beyond 225's but still being aware that they may touch the wheel wells.
Replacing an exterior or interior wheel well takes many many hours, starting with furniture removal.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-05-2006, 08:14 PM   #13
Janet's Husband's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
1977 Argosy 24 Rear Door
Eastern , Washington
Chas
Andy's fix should work. I have a different method I will be using though, only because I have the inside stripped out. I have total access to the wheel wells and will be covering them in from the inside of the trailer with fiberglass to reinforce them. I figure one layer of woven glass cloth with epoxy resin should do the trick.
Peace
Gary
Janet's Husband is offline   Reply With Quote
Old 12-05-2006, 08:26 PM   #14
Commercial Vendor
Gary.
Make it two layers.
Just in case you hit a "BIG" bump.
Andy Rogozinski
Inland RV Center
Corona, CA
Door frame cracked till Doors & Locks 11 02-14-2004 08:06 AM
windshield cracked..repair cost? Astrodokk Parts Archive 8 07-16-2003 11:22 AM
Repair cracked rock shield? Rog0525 Rock Guards, Segment & Window Protectors 5 07-12-2003 01:53 PM
Cracked door frame 77caravaner Doors & Locks 5 10-11-2002 07:43 AM
Cracked City Water Connector wagsrp Fresh Water Systems 0 08-09-2002 01:48 PM
