Old 05-25-2012, 05:21 PM   #1
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
can reg. trailer wheel wells be used?
Ok, I looked through the wheel well forums and found nothing about using wheel wells you would buy to build a flat bed trailer with. I need to replace mine as they have sagged and split in a few places.
I guess I could get some sheet metal and weld them up, but it would be quicker and easy if the pre fabricated ones would work. Has anyone ever done this?
I also want them I bit thicker than the original ones, as I don't want a blow out to take them out, or have them sag again.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 05-26-2012, 07:53 AM   #2
mapleton , Utah
I had mine made up at a local heating a/c shop pretty reasonably. only problem I had was that they missed the fact that the exterior walls are curved and had to readjust them a bit. I suspect you might have the same issue with premade units
tim
rumrunner is offline   Reply With Quote
Old 05-26-2012, 09:18 AM   #3
Airstream's inner and outer plastic wheel well covers are pretty cheap.
Old 05-26-2012, 01:29 PM   #4
purman's Avatar
1968 28' Ambassador
Thanks Andy I will look into the inner plastic but I want metal for the outside.
I spent time last night on the internet and could find nothing from a general trailer fender that would fit. So I think I will just get some 18 gage metal cut to the right size and weld it up. Then put the plastic ones for the inside over them.
I was thinking to coat the inside of the fenders with bed liner stuff you can buy in a can. I just don't want the fender to come apart if I get a blow out. And plastic or thin galvanized just gets toasted. So if Im going to have to do it i'm going to go a little over kill.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
