Old 10-31-2015, 08:34 AM   #1
1969 23' Safari
Keene Valley , New York
69 Land Yacht WHEEL WELLS
My wheel wells need replacement... Interior is gutted and has rigid closed cell insulation. Any ideas? Should I have them built from metal, or are there plastic preformed covers available? I am puzzled by how to make a secure/weather-tight attachment between inside skin and the wheel well.
Thanks so much!
Lurlene is offline   Reply With Quote
Old 11-11-2015, 09:00 PM   #2
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
The interior wheel wells in my 69 are a green vacuum molded plastic, I think your best bet is to find parts from a donor trailer or have someone bend up some metal ones.
I believe I have seen a mention on here of someone buying new ones from AS to try to use them but that the new models turned out to be too narrow to give the tires clearance.
I would recommend putting a wanted ad on the classifieds
thesignlady is offline   Reply With Quote
Old 11-11-2015, 09:28 PM   #3
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Are you talking about the metal wheel wells or the plastic cover that goes over them?
Either way, you can take them out, and bring them to a sheet metal shop. The can make new ones out of galvanized steel or aluminum.
Silverflames is offline   Reply With Quote
New tanks around wheel wells? truckasaurus Waste Systems, Tanks & Totes 0 10-12-2008 05:52 PM
sealing seams in the wheel wells.. safari25-05 Wheel Wells 6 01-16-2007 03:38 PM
Wheel wells question cameront120 Roof 4 06-11-2006 10:41 PM
Leaky wheel wells TomW Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-25-2005 01:00 PM
Plastic Wheel Wells Dennis Interior Restoration Forum 14 01-17-2003 12:05 AM
