Old 12-03-2003, 02:35 PM   #1
danesh's Avatar
working on the roof
Dear AS Friends:
I am in the proccess of stopping leaks in our AS. I have received many helpfull tips from many of you regarding caulking and sealing the vents on the roof. My question is, can I stand on the roof to do the repairs? If not, how can I reach all the vents such that I can make sure that I have done the right repairs?
Thanks for any advice.
85 sovereign
danesh is offline   Reply With Quote
Old 12-03-2003, 02:38 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I would be very careful up there. If it were me, I'd get two large "A" ladders and place planks across-- but that's just me...Airstream says you can stand on the roof, but only on the rivet lines though....
Eric
Old 12-03-2003, 02:44 PM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
Roof Access
I have a couple sections of scaffolding erected adjacent to the 'stream. I first put down a piece of old carpet on the roof, then a 2' X 2' piece of 1/2" plywood, and a couple of 2X8's from the scaffold to the roof.
After I'm on the roof, I use a couple of 1X6's to distribute the load, but I am careful to step only on the ribs, even with the 1X6's.
The more area you can distribute the weight over, the better off you'll be.
Always use cardboard or other non-marring material under the boards.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 12-03-2003, 06:33 PM   #4
I have been very successful in working on the roof of my '85 Excella without scaffolding. Sometimes scaffolds are more risk than benfit. Of course a lot depends on the job at hand, your personal weight and the care that you pay to staying on the ribs. I use a ladder standing near upright on the awning, didn't like it at first, but works. I have someone hold the ladder and I wear tennis shoes. Make sure the surface is very dry and as with any task plan the tools you need, put them in a container and place them on the top of the unit. Not where you want to spend the afternoon, but I was able to do the sealing tasks, antennna replacement, vent replacement or repair without damage to me or the unit. And finally, if you feel uncomfortable, take it as a warning and let someone do it for you. One fall will pay for a lot of sealing labor. Hope this helps.
CO_Don is offline   Reply With Quote
Old 12-04-2003, 02:01 PM   #5
danesh's Avatar
Thank you all. I think I'll take a piece of advise from each of you. I'll put a blanket first, two 2x12 (connected to eachother to make a 2x24) on the top such that it lays on top of at least three ribs. Then I'll tell the family to keep an eye on me. Wish me luck.
Cheers
85 sovereign
