Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 07-25-2008, 10:47 PM   #1
Profile:
Send a message via Yahoo to dhe9
winegard antenna
hello,
i have a winegard antenna on my roof. when i put the antenna down the wings rest in a cradle that is probably 12 inches long and 4 inches wide. the U shaped cradle was attached to the roof with a silicone adhesive. well the adhesive has dried and the U shaped cradle has come off. any thoughts on how to reattach the cradle so that the wings do not ride on the roof? what type of adhesive should i use?
thanks for your help.
david
socal
'03 19' bambi
2005 CTD DIESEL
SEMPER FI
RETIRED USMC
dhe9 is offline   Reply With Quote
Old 07-25-2008, 11:05 PM   #2
Profile:  2002 19' Bambi
Lafayette , California
I would recommend a polyurethane sealant/adhesive like 3M Fast Cure 4200. You can see it at ( West Marine: Fast Cure 4200 Polyurethane Adhesive/Sealant Product Display ).
Tim A. is offline   Reply With Quote
Old 07-25-2008, 11:36 PM   #3
Profile:
thanks,
we have a store near by and will get out there this week.
david
oceanside, calif
'03 19' bambi
2005 CTD DIESEL
SEMPER FI
RETIRED USMC
Old 10-15-2008, 07:40 PM   #4
emdubyadee's Avatar
Profile:  2007 27' Safari FB SE
Plano , Texas
Originally Posted by dhe9 View Post
thanks,
I have the same problem and my dealer gave me a tube of Vulkem and said to stick it back on with that. I haven't done it yet. I thought Vulkem was for sealing rather than adhesive.
Is using the Vulkem a good idea?
emdubyadee is offline   Reply With Quote
Old 10-16-2008, 07:55 AM   #5
Profile:
hello,
i used the 3M fast cure 4200 and went on a 2300 mile trip. i live in socal and am now sitting in flint, michigan and am happy to say that the U cradle has held fast. it has not moved and should i need ever to do the repair again then i would use the same product. if you don't have a west marine near you i would think home depot or a hard ware store might have the product.
i might add that while here in michigan we had almost 5 inches of rain over a 2 and a half day period and the 3M has done the job.
not sure how the double sided tape would work but think the bouncing down the freeway might shake it loose.
david
socal
(sitting in flint, michigan)
'03 19' bambi
2005 CTD DIESEL
SEMPER FI
RETIRED USMC
Old 10-15-2008, 09:23 PM   #6
olddog299's Avatar
Profile:  1990 25' Excella
Glenburn , Maine
Another option to consider would be 3M's double-sided industrial tape. It's hold is often good enough for solar panels. Just a thought...
Good luck with your repairs.
wil
AIR 22828
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Has anyone installed a Winegard Trav'ler Mexray Computers, Internet & Satellite 7 09-03-2008 12:45 AM
Bad Cable from Power Amp to Winegard Roof Antenna tntom Audio, Video & TV 3 06-24-2008 09:09 PM
Which Winegard Antenna? tlavergne Audio, Video & TV 20 08-26-2007 05:09 PM
Winegard LKappenman Parts Archive 1 04-30-2003 11:43 AM
