Old 06-11-2016, 10:31 AM   #15
aquinob's Avatar
Portsmouth , Virginia
Originally Posted by CaCraig View Post
Ok, nobody thought it was worth a try so I'll just cover it with elastomeric roof coating.
Not sure what your aversion to painting the roof is. If this is a '71, its not like you're going to hurt the value. A good elastomeric paint not only keeps the roof cooler but also helps to seal up the rivets and joints.
I've never done vinyl in a large area, but as J. Morgan stipulates, its probably a big PIA job with not a lot of value added over the paint and probably wont last as long or work as well. I used a product called ceramiflex that is no longer available, but there are other products that would probably work as well. It was documented here: http://www.airforums.com/forums/f478...lex-98479.html Good luck with whatever way you decide to go.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 06-11-2016, 10:36 AM   #16
lewster's Avatar
Naples, FL , Hood River, OR
[QUOTE=CaCraig;1804861]um, that's the point of this thread. I don't want to paint the roof and I'm looking for an alternative.
"Whatever Airstream is using now is some type of vinyl adhered to the aluminum sheet. I touched it a few weeks ago at the factory, but the get it that way from the supplier. If there was no benefit, Airstream wouldn't do it."
DEFINITELY NOT!!
I'm on the roof of an Airstream almost every day and I can state definitively that they are using a factory pre-coated aluminum. The white surface is an Alcoa applied factory coating that is more like a paint and NOT VINYL. It might even by a type of anodizing.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installations
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Old 06-11-2016, 02:20 PM   #17
1967 26' Overlander
Spartanburg , South Carolina
There are threads on these forums about coatings on Airstream roofs past factory. I am thinking seriously about using something called BUSKOTE on my '67 to ease the work load on my 50 year old Armstrong a/c.
Jacob D is offline   Reply With Quote
Old 06-11-2016, 10:35 PM   #18
1971 31' Sovereign
Indian Wells , California
The blue vinyl I got to re-stripe the trim has adhesive on one side and no protective coating to remove once it's down.
I should have said the factory coating looks like vinyl. It must be paint or something similar because the last I heard there is no white anodizing.
CraigCA is offline   Reply With Quote
Old 06-11-2016, 11:20 PM   #19
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
White vinyl decal for the roof to cut down on heat?
If it is what I am used to seeing on freight trailers, it is an amazingly thin layer of paint.
If is fairly durable, it wont peel, but it will become thiner yet, and in time become translucent.
Superat stultitia.
Old 06-12-2016, 01:41 PM   #20
1996 25' Excella
Tillsonburg , Ontario
One post suggested Epoxy White. Epoxy tends to chalk and like house paint it will dribble stains. If I were going to re-coat my White roof (Factory Original '96) I would be using 2 part Urethane like they use on boat topsides, aircraft and Semi-trailer bodies. I painted my boat topsides with it and the paint was tougher than any paint or other coating I have ever used. It is also highly sun resistant. Still on the boat 35 years later
JCW
JCWDCW is offline   Reply With Quote
Old 06-12-2016, 01:52 PM   #21
1971 31' Sovereign
JCW
That is the exact reason why I don't want to paint the roof.
There was a beautiful Airstream on the Phoenix Craigslist, except it had a white roof that extended much further down the sides that I think it should have. I don't want to do something so drastic that it would prevent the next person from potentially buying it because I know I'll be moving on to another in the future.
Old 06-12-2016, 01:52 PM   #22
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I should have said Imron 3500 HG instead of epoxy.
It is a urethane, but I sometimes somewhat mistakenly call it an epoxy.
Properly applied, it is tough as nails and will last a long, long, time without chalking...
http://www.axaltacs.com/content/dam/...G-Plus-Eng.pdf
Superat stultitia.
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Gotta get those trees cut down... clbolt Off Topic Forum 10 07-20-2012 01:31 PM
Classic vinyl/leather white roof ck21084 Upholstery, Blinds, Walls & Interior Finishes 5 05-27-2012 07:15 AM
cut down a zip dee awning? Jada Awnings 4 08-07-2006 04:52 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
