09-29-2013, 07:20 PM
#21
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Originally Posted by noreen&sal
We used Kool Seal two and a half years ago. It looks good and there is no chalking so far. It took about 2 quarts to do 2 coats (27 foot). Sal
Pics please, please!
would love to see how it looks now, did you guys did any particular surface prep?
Still One Nation under GOD
2 chronicles 7:14
09-29-2013, 07:25 PM
#22
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Originally Posted by carl2591
...i used KoolSeal on a mobile home... I got 5 gals at Sherwin Williams Paint store for $86 plus tax.. they had to order it in which took 3 day.. every where else the cost of 5 gals was 180 plus..
How long ago was that? $85 for 5 gals? really? do you have any pics of how it looks?
thanks!
2 chronicles 7:14
09-29-2013, 08:01 PM
#23
1981 31' Excella II
New Market
, Alabama
Gloss or flat it does not matter. As long as the light leaves it does not matter if it is specular or diffuse. The emissivity being high is what gives white paint the COOL factor not the gloss factor. White reflects about 90% of the heat but it is also good at radiating the heat it does absorb away from your roof. Aluminum and White paint absorb about the same amount of heat but the white radiates much more of the heat away. You don't need to worry about chalking but you do need to worry about mildew. Chalking is good because you always have a new clean white surface. The bad is that it may make white streaks on your trailer.
Perry
Originally Posted by VeggieBullet
Now, based on many threads there is a ton of info about the reasons about the reflectivity factor to decrease the temperature inside.
If is possible we will like some feedback from owners about the "gloss" or "flat" white roof, how does it look after a couple of seasons?
09-30-2013, 03:15 AM
#24
2005 31' Classic
Garner,
, North Carolina
thanks!
I bought the product this summer 2013. I have picture on my computer at home.. currently on big island till oct 5..
I just washed the roof top with dish detergent, that helps get any oil off, rinsed good and let dry.. a couple drops on water will do fine.
the stuff is like somewhat thick paint and i found the best way to apply is using a 3/4" ? nap roller.. check the direction it will say the length to use..
The instructions say to do first coat going north to south, allow that coat to completely dry and do second coat going east to west.
i did first coat one afternoon and had to came back next day to do second coat. be sure to wear sunglasses when doing as the amount of sun reflected back will blind you if a non cloudy day. my first day was sunny and it was a bear.. luckily, i was going over the old stuff so not too bad.. the second day was worse,, lucky it was overcast but still bright.
aloha..
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
10-04-2013, 08:52 PM
#25
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
what about this Gaco Roof?
I know its 100% silicone and silicone and AL don't really like each other but the construction supply place swore about it and for AL roofing.
Is it the clear coat or the kind of AL the issue with our Airstreams?
Cool Video
GacoRoof® - Available from worldofstains.com - YouTube
Gaco Roof Silicone Roof Products
2 chronicles 7:14
10-04-2013, 10:53 PM
#26
1972 Argosy 20
Snoqualmie
I used a product called Hyperseal. I had it left over from using it on two commercial buildings. It goes on very easy and holds up very well. I've had it for 5 years with no issues on one of the two roofs, and for the last year on the Argosy. When it eventually starts to deteriorate - they all do - all I will do is rough it up and apply another coat. Hypersealinc.com
Good stuff.
10-05-2013, 06:22 AM
#27
1981 27' Excella II
mays landing
, South Jersey
On the road now and can't do any pics, but prep was just a good scrubbing and neutralizing with vinegar just before the paint. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
10-14-2013, 03:36 PM
#28
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Good stuff.
thanks for the info, would you mind sharing some pics of the roof? thanks
2 chronicles 7:14
10-14-2013, 04:07 PM
#29
1981 27' Excella II
mays landing
, South Jersey
White roof
Here it is. Sal
Sal & Nora
AIR 42483
TAC N.J. 17
WBCCI 24740
10-14-2013, 04:09 PM
#30
1981 27' Excella II
mays landing
, South Jersey
Sorry for the bad picture. Sal
Sal & Nora
AIR 42483
TAC N.J. 17
WBCCI 24740
10-14-2013, 05:01 PM
#31
1951 21' Flying Cloud
1960 24' Tradewind
Folsom
a picture w/ 5 Airstreams AND the U.S. Flag can never be a "bad picture" . . .
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
10-14-2013, 09:05 PM
#32
1999 34' Excella
Hillsboro
. God bless America... Land that I love...
Peace and Blessings..
Channing
WBCCI# 30676
10-15-2013, 05:29 AM
#33
1981 27' Excella II
mays landing
, South Jersey
I guess I finally did something right. Even a broken watch is right twice a day. Sal
Sal & Nora
AIR 42483
TAC N.J. 17
WBCCI 24740
10-18-2013, 04:57 PM
#34
2012 27' Flying Cloud
Denver
Originally Posted by Lumatic
here's a photo
Lumatic - did you follow the process that DanielB referenced from Inland RV? Or did you simply apply Ceramiflex over the white factory AS roof?
Jim and Marsha
10-18-2013, 08:41 PM
#35
1993 34' Excella
Estancia
, New Mexico
I followed the factory directions from Sealoflex which called for using a Sealoflex acid etching primer. My roof was factory aluminum. They factory did not do white roofs in the 70s.
