Old 09-08-2011, 11:50 AM   #1
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
White roof preparation
I am seriously thinking about painting the roof white as Andy with Inland Rv suggest. My question is in the sanding how in the world is the best way to sand around all of the rivets that are about 1" apart?
If you don't sand completely around each and every rivet and I mean completely up to the edges of the rivet the paint will more than likely lift off at the edges of the rivet.
I only want to do this once so i want to "get it done" right as the Cable Guy says.
silver 67
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 09-08-2011, 12:07 PM   #2
silver 67
You use an "air sander", CAREFULLY.
There is no trick, but a lot of patience is necessary.
Old 09-08-2011, 01:35 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Originally Posted by Inland RV Center, In View Post
You use an "air sander"....
If you have access to right angle die grinder I'd be inclined to use a 3M roloc disc.
I use these for all types of metal finishing on irregular surfaces. I'd recommend the yellow or white bristle disc instead of a Green Corps sanding or Scotch Brite pad.
3M US: Roloc Bristle Disc
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 09-08-2011, 02:07 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I don't know what kind of paint you are using, but I used Flex Seal/ Ceramiflex. Nothing in the prep instructions about sanding, but a good cleaning followed by acid etch primer is recommended. I know some people have skipped the primer.
Also I have enough extra primer and Ceramiflex to do at least another roof if anyone wants it. Might be kind of hard to ship though.
Old 09-08-2011, 04:08 PM   #5
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
silver 67- How much of the roof are you painting? The center 2 panels or all the way down to the awnings? Been thinking of doing the same thing just not sure how far down to bring it.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 09-08-2011, 04:28 PM   #6
1994 30' Excella
Mississauga , Ontario
Tim,
Yours is an older trailer that did not have a white painted roof. The curve of your roof is quite dramatic compared to the later trailers. I would be inclined to keep the white paint up on top where it is not too noticeable. That way it looks more original.
But it won't have quite the cooling effect.
By the way, has anyone who has done this any comments on how much cooler it seems to keep the trailer?
Al
Al and Jean
TAC ON-3
Old 09-08-2011, 04:32 PM   #7
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Al,
Thanks for the info as I was concerned that it might be show too much.
Tim
TAC MI 14
Old 09-08-2011, 05:10 PM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I am thinking about doing the center top panel on my 66. Its the only part I don't want to shine!
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 09-08-2011, 05:37 PM   #9
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
When we were at the Restoration Rally in June, Levon had done it with Kool-coat (sp?) on a trailer. He said it made a significant difference. We're probably going to do it at some point based on his recommendation. We have an older trailer so will keep it to the very top panel.
Kay
Old 09-08-2011, 07:32 PM   #10
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
We painted our 1977 down to the awnings but not the hemispheres. You could walk by it and not notice. Difficult to run a scientific test but I think it was about 10 degrees cooler on a hot no cloud no air day at Rapid City the second time around. The first Rapid City International at 104 inside the trailer convinced me to give the white paint a try. It still was not pleasant even with the white paint but a little better.
Old 09-09-2011, 12:22 PM   #11
Sorry, but any kind of acid, should never, EVER, be used on an Airstream.
Quite well, in time, you will have more water leaks around the rivets, "than you can count".
That's why sanding, "is the safe way".
Old 09-09-2011, 02:28 PM   #12
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I'm so pedestrian that if I needed to paint the roof white, I'd prep what I could and then just paint. If some of the paint flaked off later, it wouldn't affect the sun-reflecting properties at all.
Hard to see your defects from the street.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 09-09-2011, 02:44 PM   #13
1994 30' Excella
Not to argue with you Andy, but that self etching primer is designed for prepping aluminum for finish paint. I would think that the amount of "acid" is not enough to remain active. This is not the same as the method I've seen before where there was talk of washing the aluminum with an acid wash.
By the way, my trailer is a '94 that was made with panels that were supplied by Alcoa prefinished to Airstream. Seems that there was a cleaner applied to the raw aluminum to prep for the clear coat. Not rinsed properly or neutralized and the finished trailer started to oxidize under the clearcoat on dealers lots. Evidently Airstream decided the only way to fix the problem was to strip the clearcoat and paint the affected trailers to be able to sell them. Mine was painted by Can-Am rv in 1994 and the paint job still looks like new except for one small area where the clearcoat has peeled. The primer and aluminum paint are still intact.
How should I go about touching up the failed clearcoat.
Al
Al and Jean
TAC ON-3
Old 09-09-2011, 02:58 PM   #14
Al
Self etching acids get underneath the rivet heads, causing water leaks.
Acid etching cannot possibly prepare the aluminum surface as well as sanding, to assure one's self of a proper primer bond.
We have seen way too many "paint failures" when acid etching was used, along with tons of leaks.
Make a test by making a small panel with the acid etch, and then another panel with proper sanding. Install the primer, then the color, and finally the clear coat.
Let those sample cure out in the sun, for a few days.
Then, bend the samples 45 degrees or better, and observe the results.
The acid eltch will fail, the sanded sample "won't fail".
When I get back to the office, if you wish, I could post a photo of the sanding preparation method, when the metal was bent more than 90 degrees, by an accident.
The paint is not even cracked, let alone chipped off.
New Warm white Recessed Puck Lights Dan@LED4RV Commercial Listings 17 11-11-2015 10:10 PM
Wide White Wall Tires wasagachris Tires 14 08-04-2011 10:32 PM
Sloped Roof Under Air Horns Johns5711 Land Yacht/Legacy Motorhomes 7 07-27-2011 08:02 PM
