Old 09-09-2011, 07:31 PM   #15
my3sonsdad's Avatar
1975 Argosy 26
Vienna , VIRGINIA
Originally Posted by Inland RV Center, In View Post
When I get back to the office, if you wish, I could post a photo of the sanding preparation method, when the metal was bent more than 90 degrees, by an accident.
The paint is not even cracked, let alone chipped off.
I recently came across the mentioned photo....very impressive:
http://cdn.airforums.com/forums/atta...6&d=1081371878
1975 Argosy 26
2015 Jeep GC Summit EcoDiesel w/Hensley
my3sonsdad is offline   Reply With Quote
Old 09-09-2011, 07:37 PM   #16
painting
We keep that damaged motorhome door, for those that "gotta see it, in person".
As with many things in life, there's the cheap way, and the right way.
Everyone has the choice.
Old 10-22-2011, 01:49 PM   #17
1974 Argosy 22
1976 Argosy 28
1972 Argosy 24
Chico , California
I'm on a ladder right now sanding my Argosy roof in prep for repaint. Not easy, but I like to do it once. my cheap tool store Harbor Freight has a nice little triangle head multi tool for going around the rivets. My question is: has anybody used snowroof on the top? They also have something called mobile roof. (snowroof.com) Seems to me the prep would be less as you are just getting the loose stuff off. Any experience in this? Thanks Tom
twilder is offline   Reply With Quote
Old 10-22-2011, 03:04 PM   #18
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
I just sanded the top of my 71 31' and am taping off to coat it with SuperTherm. Was a lot of work but will be worth it.
Darkspeed is offline   Reply With Quote
Old 10-22-2011, 06:11 PM   #19
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I put Super Therm on the roof of my Excella this summer. Following the suggestion of the local representative, I scrubbed the roof with a green Scotch-Brite pad and dish detergent. Then I rolled on a couple of coats of Super Therm. I also covered the vent lids and the AC cover. I had a little left over from two gallons. Not bad for coating the top of a 34' Airstream.
Vaughan
Old 10-22-2011, 06:31 PM   #20
Darkspeed's Avatar
1972 31' Sovereign
eeeek... I guess I overshot ordering the three gallons
Old 10-22-2011, 06:39 PM   #21
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Sno-Roof is one type of elastometric roof coating. There are many brands, I've used Kool-Seal on a couple, Sno-Roof on a couple, and used Henry's and Heng's on two others. As long as it's properly prepped, any ot=f them will work fine.
There were opinions several years ago this stuff would cause streaks down the sides of Airstreams. I haven't had that problem with any I've done, and our Sovereign has been treated (painted) since early 2009 with no streaks. I guess that opinion has been quietly shelved.
Old 10-22-2011, 08:11 PM   #22
1983 34' Excella
1967 24' Tradewind
Images: 32
Maybe you could find a Bambi to soak up the rest.
Vaughan
New Warm white Recessed Puck Lights Dan@LED4RV Commercial Listings 17 11-11-2015 09:10 PM
Wide White Wall Tires wasagachris Tires 14 08-04-2011 09:32 PM
Sloped Roof Under Air Horns Johns5711 Land Yacht/Legacy Motorhomes 7 07-27-2011 07:02 PM
