Old 06-11-2016, 03:26 PM   #1
1985 34' Sovereign
Nashville , Tennessee
White Roof coating, would you do it again?
Looking for input on a white roof paint/elastomeric coating for both sealing and heat rejection properties. If you have a NON-factory white roof, please post up camper, type of coating and age of coating, and your experiences/would you do it over?
Context: I'm renovating/full timing in a 34' 1985 sovereign in lower Alabama. Stripping and sealing the roof got me to thinking that lower Alabama = extreme heat + pop up storms and a white sealed roof mitigates both problems at once.
My 1985 owners manual says to re seal the roof with Kool-seal, and that is definitely the most available elastomeric coating out there. I'm a chemical engineer, though, and my instinct is telling me a combination of surface prep, primer, and an extremely tough urethane will get the longest lasting results. I've been eye-balling Imron 3500HG, or Interlux Brightside as they get stellar reviews. I'm just unsure if they are elastic enough for this application, or which primer is best. Do I even need a primer at all? Imron seems to claim it goes well over any reasonably prepped metal, and I'm not afraid of sanding this thing since 1985 is not exactly a collectible year and the interior is mostly gone
Oh and plasticoat is 95% gone other than a few awkward vertical strips.
SovrnScout is offline   Reply With Quote
Old 06-11-2016, 04:33 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I used Truco coating. I had some left over from a commercial project. I put it on about 10 years ago, sold the trailer, but it is still on their and working well.
Aaron
WBCCI #XXXX AIR #2495
Old 06-12-2016, 08:11 AM   #3
1985 34' Sovereign
Aaron
That sounds like what I was hoping to hear, do you remember which coating you used?
Old 06-12-2016, 08:23 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Probably the 7140 or the 7140-FM, we had all of them on hand at one time or another. Given the time frame I did it that was probably what we were using.
Aaron
Old 06-12-2016, 12:03 PM   #5
1974 25' Tradewind
Lexington , Kentucky
White roof paint
On our 74 Trade Wind:
Removed all (what there was) of the clearcoat.
Wet sanded with 220 grit wet-and-dry sandpaper.
3M blue tape along the edge.
6 inch roller with broom handle....applied Rust-Oleum Aluminum primer then rolled Rust-Oleum Gloss white paint = looks great.
May need another coat though.
Gluck.
The Twinkie is offline   Reply With Quote
Old 06-12-2016, 12:20 PM   #6
Jeff I
2007 25' Safari FB SE
1964 22' Safari
Hammondsport , New York
Roof coating
I was in the coatings business for 45 years and the Truco 7140 is the toughest flexible coating I've ever seen. Should adhere great to a clean surface.
J Ingersoll is offline   Reply With Quote
Old 06-12-2016, 12:56 PM   #7
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
I've used this product, Bus Kote, on both a previous Airstream and a Foretravel motor home we've owned. When our current Airstream needs a coating, will use it again. Excellent for roofs, sealing and insulating.
http://www.hytechsales.com/prod2150.html
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 06-12-2016, 01:26 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I used Imron 3500HG three summers ago. Today it is the same as I put it on, it is an EXCELLENT product.
No primer is required if you sand well, and it is plenty elastic enough to stick on aluminum for many years. I started using the stuff eight or nine years ago, no peeling, chalking, checking, or fading to this day.
It makes a huge difference in full sun, if I put one hand on the white and one on bare aluminum, I can bear it for a perhaps a second on bare aluminum, but indefinitely on the painted surface.
Superat stultitia.
Old 06-12-2016, 03:18 PM   #9
Caroyl's Avatar
1964 26' Overlander
Warner Robins , Georgia
Would you use this on a vintage trailer?
Caroyl & Tim
1964 Overlander "Gracie"
WBCCI # 31088
2009 F-150 "Big Red"
Caroyl is offline   Reply With Quote
Old 06-12-2016, 06:34 PM   #10
E Pluribus Aluminus
Jaxon's Avatar
1967 22' Safari
2005 30' Classic
Rockport , Texas
I used the Bus Kote on a ’67 Airstream Safari with excellent results.
Bill & Kim
Old 06-12-2016, 08:20 PM   #11
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
If I was going to camp in it I would.
If I was just going to admire it maybe not.
Superat stultitia.
Old 06-12-2016, 08:50 PM   #12
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I did my 71 with Ceramiflex (no longer available) Still good going on 10 years. I will also do my 93. It's a no brainer here in the southwest.
Lumatic is online now   Reply With Quote
Old 06-13-2016, 12:04 PM   #13
2008 30' Classic
Orland Park , Illinois
J.Morgan,
I looked up the Imron and I've found Imron 3.5 HG+. Is this what you have used or is there really an Imron 3500 HG, or have they changed the name somewhat for some reason. The 3.5 HG+ has excellent properties from their Tech Data Sheet. I'm excited that there is such a "paint" that can be rolled, brushed or sprayed and can be recoated years later with minimal prep. Almost seems "too good to be true"!
flyerboy is offline   Reply With Quote
Old 06-13-2016, 01:43 PM   #14
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
It is really good stuff.
I have used it fairly extensively.
IMO it is better, stronger, more forgiving, and cheaper than anything comparable paint including automotive paint.
Here is a link to some of the things I have painted with it.
http://s245.photobucket.com/user/JMD...hop/Imron%2035
<div style="width:480px;text-align:right;"><embed width="480" height="360" src="http://pic2.pbsrc.com/flash/rss_slideshow.swf" flashvars="rssFeed=http://feed245.photobucket.com/albums/gg64/JMD_LCMS/LR%20Shop/Imron%2035/feed.rss" type="application/x-shockwave-flash" wmode="transparent" /><a href="javascript:void(0);" target="_blank"><img src="http://pic.photobucket.com/share/icons/embed/btn_geturs.gif" style="border:none;" /></a><a href="http://s245.photobucket.com/albums/gg64/JMD_LCMS/LR%20Shop/Imron%2035" target="_blank"><img src="http://pic.photobucket.com/share/icons/embed/btn_viewall.gif" style="border:none;" alt="JMD_LCMS's album on Photobucket" /></a></div>
Superat stultitia.
What would you do different if you were placing your concrete your pad again? dznf0g Winterizing, Storage, Carports & Covers 57 06-10-2015 10:27 AM
White roof coating ? shineybullet Exterior Restoration Forum 16 06-09-2015 02:08 PM
White roof coating maintenance ???? polarlyse Roof 11 03-31-2015 10:00 PM
Logging In Again and Again and Again Secguru Forum Admin, News and Member Account Info 4 11-01-2010 12:15 PM
Do you have rubber coating on the roof? dbtolman Roof 22 03-16-2009 05:29 PM
