Old 06-16-2016, 10:03 AM   #29
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Those of you who have recoated -
Did you remove the caulking around the fixtures first? The fixture caulking isn't too old on my trailer.
Steve, Christy, Anna and Scout (Border Collie deceased 11-30-2016)
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 06-16-2016, 10:34 AM   #30
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Originally Posted by lightmind View Post
I am leaning towards using Rustoleum Noxyde or Peganox on my rebuild, a 1977 Sovereign...
Rustoleum is a very good unactivated enamel in my opinion.
Superat stultitia.
Old 06-16-2016, 10:37 AM   #31
2008 30' Classic
Orland Park , Illinois
Cool Imron 3500 vs 3.5
J Morgan,
Can the Imron 3500 be rolled and brushed on or is it just the Imron 3.5 that can be rolled and brushed. I checked the tech data and the 3500 only gives spray instructions. Have you successfully rolled or brushed the 3500?
I want to order this stuff but I believe the aircraft version 3500 might be even better than the 3.5 HG but I definitely can't spray the 3500 if indeed that's the only recommended application method.
If that's the case, I'll have to go with the Imron 3.5
Thanks, I really appreciate your input and info!
flyerboy is offline   Reply With Quote
Old 06-16-2016, 11:15 AM   #32
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I have a good friend in the commercial roofing biz. Ive been thinking about talking with him about the possibility of using a white EDPM membrane on the roof of my 310. Do you folks know of anyone who has done this before? Im thinking more for the reflective surface rather than water protection but of course youd get both if applied correctly. I think it comes in various thicknesses. I would think that the aluminum would provide a good surface to adhere to. Any thoughts?
Mike
mayco is offline   Reply With Quote
Old 06-16-2016, 11:33 AM   #33
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I should have said 3.5, I am stuck in the past. It is really the same stuff, just updated a bit.
It is equally brushable and rollable.
Superat stultitia.
Old 09-12-2016, 07:16 AM   #34
Goliad , Texas
You posted this at a perfect time in our renovation. We have a slick roof on our '65 Overlander and have been prepping it for new installs of fans, AC, antennae and skylights.
I have been polishing end pieces and debating whether to polish entire roof since it has not been done in 51 years or just give it a good rough up and paint a good heat barrier on it. Well, finished end pieces yesterday and ready to proceed with patches and either polishing or sanding.
I think it will be sanding and painting with the bus paint. 500 quizillion bus tops cannot be wrong.
Plus, my wife unit likes painting better than buffing BUT she loves to buck rivets.
The Frommes
Goliad, Texas
The Birth Place of S. Texas Ranching
WBCCI #6256
eartick is offline   Reply With Quote
Old 09-12-2016, 09:33 AM   #35
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
This IS a very timely thread....
I have been in contact with reRubber, a company in California that makes many different coatings that include ground up rubber from recycled truck tires. I have used their Automotive Coating to coat the frame and wheel well area of our Avion, and used same to undercoat our Bronco and F250. LOVED that product and recommend it highly. Easy to use, and very "green".
They have acrylic elastomeric roof coatings as well. They are sending me samples of a grey primer coating and their white Top Coat that includes glass spheres to help reflect heat/rays. Looking forward to receiving those this week.
Has anyone else here used any products from reRubber?
http://www.rerubber.com
"Long lay the world in sin and error pining
Till He appeared and the soul felt its worth"
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 09-12-2016, 10:26 AM   #36
Goliad , Texas
Rerubber sounds interesting. Would be interested in how you think it works out.
Did you apply the under coating yourself and if so what special tools did you need?
The Frommes
Goliad, Texas
WBCCI #6256
Old 09-12-2016, 10:41 AM   #37
PaulnGina's Avatar
Good Ol' , USA
Their Automotive Coating was pretty awesome stuff. It is water-based, so your tools (brushes, sprayer.... And YOU!!!&#128512 clean up easily, especially before it is allowed to dry. Once dry, though, it is a very hard, durable coating. I brushed it on using a utility-grade brush.
The Automotive Coating can be used as a bed liner, also. And, maybe in some of reRubber's YouTube videos, I remember seeing entire vehicles coated with it.
1987 Avion 34W
Old 09-12-2016, 10:44 AM   #38
PaulnGina's Avatar
Good Ol' , USA
White Roof coating, would you do it again?
Also, if you search the Forum for reRubber, I think I mentioned their product before, and posted a picture that shows the wheel well area of our Avion??
Picture might also be in my picture albums somewhere.
1987 Avion 34W
Old 09-12-2016, 10:54 AM   #39
PaulnGina's Avatar
Good Ol' , USA
Found it.....
Name:	ImageUploadedByAirstream Forums1473695641.528677.jpg
1987 Avion 34W
Old 02-12-2017, 09:09 AM   #40
2010 25' FB Flying Cloud
Davenport , Iowa
Did any of you remove the AC and vents and caulk before using the Bus Kote?
Airtandem is offline   Reply With Quote
Old 02-12-2017, 10:28 AM   #41
1976 31' Sovereign
Oswego , Illinois
Any white on roof helps lower temp inside but bus-kote has ceramic parcels in paint. I have used Imron, it will kill you if not using proper air mask. Yes Imron is a hard coat but not worth cost and effort to prep and apply on roof of AS. unless you are a pro. My #2 son has degree in auto repair and body work, my knowledge is first hand plus gov. restrictions on spray painting auto paints are enormous. Final Imron more exp than bus-kote. I would use but won't go on roof any more at 83 yrs. old. Not worth with little time left to use AS.
Old 02-12-2017, 12:08 PM   #42
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
I dinít remove the AC or vents, just took off the old caulk and reapplied prior to putting the bus kote on.
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
What would you do different if you were placing your concrete your pad again? dznf0g Winterizing, Storage, Carports & Covers 57 06-10-2015 10:27 AM
White roof coating ? shineybullet Exterior Restoration Forum 16 06-09-2015 02:08 PM
White roof coating maintenance ???? polarlyse Roof 11 03-31-2015 10:00 PM
Logging In Again and Again and Again Secguru Forum Admin, News and Member Account Info 4 11-01-2010 12:15 PM
Do you have rubber coating on the roof? dbtolman Roof 22 03-16-2009 05:29 PM
