Old 10-11-2014, 04:54 PM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
White roof coating maintenance ????
I asked this question recently in an existing thread then I forgot where it was and can't find it. SOOooooo here goes, again. Is there any periodic maintenance that should be done on the roof with the white coating. Actually what is the coating ???? Is it paint ??? Now I really mean other than the obvious sealing the vents that is. Can you / should you wax the roof as we would do for the sides ??? My old trailer did not have the white coating and I eyeballed the seams and rivets and checked the vent stacks and all the caulking on the roof. Haven't been on the roof of my newer trailer though.
Does the roof coating deteriorate and need to be periodically re-done ??
Thanks all.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 10-11-2014, 05:06 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Thanks all.
If it is the factory installed stuff I believe it is a high end baked on enamel that requires minimum care. Wash and wax occasionally shouldn't hurt it at all.
Aaron
WBCCI #XXXX AIR #2495
Old 10-13-2014, 07:55 AM   #3
retired USA/USAF
2001 30' Excella
Thanks Aaron. Washing it gets. Wax may come when I get my ladder
Roger in NJ
TAC - NJ 18
Old 03-25-2015, 10:19 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Thread 'reboot'....
The roof of our 1999 34' has nearly completely 'chalked' over. When checking around, I noticed 'silver' around the roof rivets... and some cracking of sealant.
So... to me, it is necessary and will need to do soon.
Now.. do I use the Rustoleum 'nano technology' spray or roll on which can coat the roof giving good water 'run off'? Or the 'roof cool' stuff the SOBs use?
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-30-2015, 06:51 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Any help guys and gals?????
Channing
WBCCI# 30676
Old 03-30-2015, 07:04 PM   #6
dznf0g's Avatar
Oswego , Illinois
I use a hose end mop, which removes the oxidized paint well. I don't wax the white..only the clear. There are threads that discuss the ceramic coatings (name escape me right now) which help (arguably) with sun/heat mitigation. I probably will go that route when I see silver bleeding through. Till then minimum of washing, no waxing.
-Rich-
Old 03-30-2015, 07:06 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Thanks! I think the name is Ceramiflex.. Trying to find some!
Old 03-30-2015, 07:09 PM   #8
dznf0g's Avatar
Oswego , Illinois
Yes, that's the "better" of the ceramics....the other was Kool Seal, or something like that.
-Rich-
Old 03-30-2015, 07:29 PM   #9
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I wax my white roof and it stays like new.
Old 03-30-2015, 07:47 PM   #10
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
It was recommended to me at the factory to use an automotive paste wax on the white painted roof. Was told it would stop the white streaks from running down the sides after a rain. It is on my to do list.
MICHAEL
Old 03-30-2015, 08:09 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
thanks, y'all! I certainly agree, caring for the roof is a great idea... too late for ours, but, still, a great idea!
Channing
WBCCI# 30676
Old 03-31-2015, 09:00 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ok, y'all..
Found this:
http://www.thortex.com/wp/wp-content...data-sheet.pdf
Looks very strong... maybe too strong to allow roof flex?
Here is a more extensive list.. and, yes, it is 2 Part epoxy based it appears..
3M Ceramic Enhanced Protective Coatings - Thortex | The Thortex Group
or
Chemical/Corrosion Resistant Coatings - Thortex | The Thortex Group
Also, there are other 'epoxy' based coatings which have different 'activators'.. Low VOC, Low Temp, Fast set, etc.. One I do not clearly comprehend is a 'water activator'... does that mean it hardens with contact to water?
Channing
WBCCI# 30676
Do you have rubber coating on the roof? dbtolman Roof 22 03-16-2009 04:29 PM
Removing black roof coating lessen Cleaning, Stripping & Polishing 1 06-02-2006 09:55 AM
removing roof coating airtim Cleaning, Stripping & Polishing 2 04-02-2005 09:43 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
Roof coating FrankR Roof 4 07-22-2002 01:56 PM
