Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 06-09-2006, 06:57 PM   #1
cameront120
cameront120's Avatar
Profile:  1972 25' Tradewind
Wheel wells question
Is there a gasket between the outer aluminum skin and the plastic wheel well liner on the 70's models? Several rivets have sheered and before replacing them, I'd like to know if there is anything that should be done to assure water tightness. Any tips would be appreciated. Thanks in advance!
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 06-09-2006, 11:33 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
There must be sealer between the housing and the skin. I would suggest a dab of sealer in each rivet hole, and around the rivet shaft, as well as making sure the plastic housing's seal isn't broken where the rivets have sheared. Why did the rivets shear in the first place?
Uwe
Old 06-10-2006, 01:38 PM   #3
cameront120
Uwe, I'm assuming they sheared over time with the movement of the trailer while being towed. It's a '72, and I fully expect to find rivets that have failed here and there. Aluminum will fatigue faster than steel under repeated motion...at least this has been my experience with aluminum vs. steel mountain bike frames!
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 06-10-2006, 02:19 PM   #4
uwe
418
uwe's Avatar
Images: 40
You might want to take close look at things around the wheel wells. If rivets sheared, then often there are associated issues with either the floor or elsewhere.
Good Luck!
Uwe
Old 06-11-2006, 10:41 PM   #5
fly2havefun
fly2havefun's Avatar
Profile:  1968 26' Overlander
Carbondale , Colorado
Exclamation Double skins on one side????
I just started doing some much needed repairs on my '68 Overlander as well. Polishing, rear end separation, you name it. You can't have too many things going on at once, you know! Anyway, on my one side of the A/S I noticed it looks like someone went over the outer skin at the wheel well area with another skin! Has anyone ever heard of doing that??? I'm pretty sure it was to add some sort of strength there as I have some outriggers that need to be replaced...three on that one side! (two partially there, one missing). Someone really botched this up. But 'lo and behold, I will fix it, with help! I still need to remove a bunch more rivets to find out what's what, but I will be doing work on my wheel well, also, and if there's any more advice...let's hear it! Thanks in advance!!!
Becky
fly2havefun is offline   Reply With Quote
Wheel Bearing Adjustment Dwight Axles 9 05-15-2008 05:50 AM
Wheel Chocks pjtaia On The Road... 13 10-28-2005 02:27 PM
Plastic Wheel Wells Dennis Interior Restoration Forum 14 01-17-2003 12:05 AM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
The Junkyard Wheel Story Inland RV Center, In Wheels 1 04-10-2002 06:04 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
