Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 11-04-2007, 07:46 AM   #1
Profile:  2005 34' Classic
Richmond , Virginia
Walking on the roof - cleaning / inspecting
My roof is starting to get fairly dirty and Id like to clean it before its too bad. Also Id like to inspect the sealant around the vents and stuff. Does anyone have any setup ideas for getting on the roof without screwing up the aluminum?
Resorts is offline   Reply With Quote
Old 11-04-2007, 08:45 AM   #2
Profile:  1968 26' Overlander
Ann Arbor , Michigan
Images: 11
I would like to know the answer to that as well. My 68 "O" is in need.
Aluminati is offline   Reply With Quote
Old 11-04-2007, 08:56 AM   #3
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Walking on roof
Airstream say's you can walk on the late model roof's and they walked all over mine with no damage.
I walk on the ribs when washing or repairing and would walk on the ribs of older units.
Gunny
Gunnyusmc is offline   Reply With Quote
Old 11-04-2007, 09:14 AM   #4
Richmond , Virginia
Gunny
Did you see any flex when you walked across the ribs?
Old 11-04-2007, 09:20 AM   #5
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Walking on roof
None.
Gunny
Old 11-04-2007, 09:37 AM   #6
Royce's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
When the time comes that I need to get on top of the Minuet, I will make a bent lamination to fit the curve of the roof. Figure about 18" wide by 5' long should be about right. Easy for me as I make bent lanmintion on a regular basis in suport of other parts of my custom design business. If you have access to someone that can make same locally ask and see what they would charge. Otherwise give me a call when you travel through Colorado Springs and I can arrange to make one customized to fit your coach.
Royce (KORKK) and Karen
AIR# 3913
'77' Minuet 6 Metre TV: '94' Wrangler, 4.0L inline 6, Ford 8.8 rear, NV4500 tranny, Old Man Emu suspension, 30x9.5 tires
Royce is offline   Reply With Quote
Old 11-04-2007, 09:11 AM   #7
Richmond , Virginia
I think id still be afraid to walk on it. If I push down between the ribs it does flex. Id hate to stretch the rivet holes and create a leak. I was thinking about making some kind of platform but Im not sure what the best way is to set it up. I have steped on the rib one time but it can get slick up there.
Old 11-04-2007, 11:47 AM   #8
gotohatteras's Avatar
Profile:  2006 23' Safari SE
Avon , North Carolina
If you just need to wash it with brush or mop on a pole...use a 10 ft. step ladder, put it as close to camper as you can, have someone lean against it on the opposite side while you are on it doing your was thing. Also, what I did when inspecting the seals, and replacing a vent cover, was to lean one of those aluminum teloscoping ladders against a rib area(with towel wrapped around it for marks) and got on rib area as much as possible, but laying on butt with a leg crossed under you seems to spread out the weight sufficiently. Just be careful not to slip off on the edge. Dents to aluminum aren't as important as dents to your body!
DW always tells me to "take the high road"...
2006 23' Safari
2007 F350 Lariat Crew 4X4 PSD
AIR# 21875
WBCCI# 3778
Region 3, Unit 144 (Eastern North Carolina)
gotohatteras is offline   Reply With Quote
Old 11-04-2007, 12:19 PM   #9
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
Savannah , Missouri
Send a message via ICQ to 53flyingcloud Send a message via Yahoo to 53flyingcloud
This an excellent time to pass on this reminder..
Weight limitations for the Airstream roof is, as stated by Airstream, 250lbs on the rivet line.
Be careful~
53flyingcloud is offline   Reply With Quote
Old 04-26-2008, 07:22 PM   #10
Usually Sleepy
Profile:  1973 27' Overlander
1972 Argosy 22
East Haven , Connecticut
Images: 16
Be careful~
which is why I do not get on my roof (6'5" 280lbs). Luckily, with that disadvantage comes really long arms. 6 foot ladder and a scrub brush for me to clean and I can reach to the middle of the roof with my hand or any hand tools when needed.
If you're in southern CT, email me and I'll help anyone who needs it.
biggoofball is offline   Reply With Quote
Old 11-04-2007, 01:32 PM   #11
Tincrew's Avatar
Profile:  2007 25' International CCD
San Diego , California
Jim washed & waxed ours using 2 ladders and a plank. Never actually put his weight on the roof. Would recommend padding on the awning to protect your chest though.
Good Luck,
Leslie
Tincrew is offline   Reply With Quote
Old 11-04-2007, 02:00 PM   #12
Richmond , Virginia
Good Luck,
Leslie
Thats kinda what I was thinking about doing. What size and type ladders did you use? I bet it could get a little shaky up there.
Old 11-04-2007, 04:45 PM   #13
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
I use a folding ladder similar to a "Little Giant" but generic and cheaper. I fold the top section at an angle so it rests on the roof. The next section down rests against the side of the coach. I glued carpet scraps to the inside ladder frame where it contacts the skin. To move around on the roof I use several planks to distriubute my wieght.
Pay no attention to the man behind the curtain- WoZ
Old 11-05-2007, 11:06 AM   #14
Commercial Vendor
Profile:  Corona , California
This subject has been kicked around many times, on this forum.
WALKING ON THE ROOF OF AN ARGOSY OR AIRSTREAM TRAILER IS OK,
as long as you stay within the length of the awning rail.
DO NOT go beyond the length of the awning rail.
Leaning a step ladder against the drip cap that's on top of the windows from 1966 and up, will not damage the trailer.
Many years ago Airstream had 30 (thirty) mechanics stand on the roof of a 30 foot trailer. They water tested it after the fact, and found no leaks.
Walk with caution and stay on the horizontal stringers, when ever possible.
Obviously, you don't want to do any rock and rolling dances while on the roof.
Having special ladders, platforms and the like, is a waste of time and money.
No dealer or the factory, ever has a problem walking on the roof. They all do it.
Wear soft sole shoes or sneakers when on the roof.
DO NOT attempt to get on the roof if it's wet, or even damp. If you do, you will probably fall off, very quickly.
Andy Rogozinski
Inland RV Center
Corona, CA
Cleaning Brad Hunt Cleaning, Stripping & Polishing 6 09-14-2007 04:17 PM
Excella Requires Roof Cleaning Streamer1 Roof 6 10-18-2006 04:27 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 10:59 PM
? Cleaning Toilet ? srae Sinks, Showers & Toilets 8 08-14-2003 02:30 PM
