Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 09-10-2009, 06:45 PM   #1
Judy Barde's Avatar
Profile:  1960 24' Tradewind
pittsburg , Kansas
Vent leak
This summer while camping it really rained all night first time to stay in the trailer while it poured. Noticed a puddle about the size of a quarter on the floor under the front vent. I have a feeling it has always been there and just didn't notice it. It can rain all night and the drip is dry by afternoon that is how small it is.
I went up on top and added par 635 around the entire vent as it looks pretty good and flat nothing like the fan vent. I replaced the gasket. It still has the minute drip. I really don't want to take the whole vent out as for me this is a major job(HUM) Any suggestions? I redid my fan vent but it was very obvious that it was bad this one just looks so good I hate to take it out and thought someone may have a few suggestions to try first thanks Judy
ID:	86981   Click image for larger version
S. Silver
Judy Barde is offline   Reply With Quote
Old 09-11-2009, 05:33 AM   #2
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Try replacing the foam gasket, easy job
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
LI Pets is online now   Reply With Quote
Old 09-11-2009, 08:58 AM   #3
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Hi Judy ~
While I agree you should replace the foam gasket, you should also get replacement lifters so the cover can be cranked down tight and compress the foam when closed. How is the cover attached to the frame now?
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 09-12-2009, 09:24 AM   #4
Judy Barde's Avatar
pittsburg , Kansas
vent leak
I did replace the gasket. 1 lifter is there and I have the other side wired down and it is tight against the cover. I have the lifter but wanted to take care of the leak before I replace.
thanks
S. Silver
Old 09-12-2009, 08:47 PM   #5
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
Maybe a different gasket would help. Either the foam gasket that is recommended or on like comes on the vent assembly shown. Put it on in one piece so there is only one seam....
Vent Gasket for Solardome SKU2977 - $0.45 : ODMRV , Out-of-Doors Mart
Elixir crank-up vent 31-1998 [31-1998] - $32.95 : ODMRV , Out-of-Doors Mart
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 09-12-2009, 10:12 PM   #6
Profile:  1966 30' Sovereign
1963 22' Safari
orlando , Florida
Images: 8
Seal all the way around the outside where the vent is riveted to the skin.I had a tricky leak in the same vent.Never did replace the foam,but the outside sealant did stop the leak.
richie rich is offline   Reply With Quote
Leak at roof vent Nightwind15 Roof Vents, Skylights & Fans 3 12-27-2008 10:32 AM
What To Use?:leak Around Tank Vent ROBERT CROSS Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 05-31-2008 03:04 PM
Leak around range hood vent '74 Tradewinds chuman70 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 05-29-2007 03:54 PM
Vent Cover Leak Tom Nugler Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 06-05-2006 04:36 PM
Vent pipe leak - How? TomW Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 12-25-2003 10:11 AM
