Old 04-24-2004, 05:18 PM   #1
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
up on the roof top
I have my Walbernize and my awning cleaner and my car wash, my longhandled brush, hose, chamis and cloths, but just how, oh how, do you get to the roof? I put the ladder right next to the Airstream but I don't even come close to reaching. How do you polish the roof?
And may I ask has anyone changed the Safari one step to two?
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 04-24-2004, 05:46 PM   #2
ctdair's Avatar
I used a six foot step ladder and used the lip above the awning and the window drip channel (very amatuer rock climber(helps)).climbed on roof in stocking feet and walbernized.
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
ctdair is offline   Reply With Quote
Old 04-24-2004, 05:54 PM   #3
Lapeer , Michigan
aeroacrobatics without a net?
Gosh. Did I mention I am 5'2? Looks mighty daunting just from the top of the ladder. Can you step anywhere on the roof or only certain places?
Caroljb
photography
Old 04-24-2004, 06:11 PM   #4
Cartoon Character
Porky Pig's Avatar
2004 34' Classic
On The Road , U.S.A.
Great thread ... as I am in the market for a ladder to take with me on our travels.
I saw a ladder at Orchard Supply Hardware that was identical to the Little Giant .. as seen on TV ... but was priced much less at $199 ... still pretty expensive .. so I passed.
During the Escapade Rally this week I purchased two Extreme Vents ... paid 10 bucks to have them installed since I didn't have a ladder.
The installer showed up with a clone of the Little Giant ... and I was amazed with how easy it was for him to just step up onto the top of my AS. So I climbed up to for a look .... and was convinced that the model I saw at OSH was worth every penny. I'll be getting one soon.
Porky
TrailerGypsies.com
WBCCI #3405 Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
Old 04-24-2004, 06:14 PM   #5
ctdair's Avatar
Yes allmost forgot to mention , it is real important to stay on the rivet lines that are holding the skin to the ribs. the line is two rows of rivets wide and runs side to side on the trailer . the single rivet lines are just holding the panels together and there is no structure that will support your weight under them. most of them run front to back but the are several areas that do go side to side single rivet. stay on the double riveted ribs.
S/OS #010
Old 04-24-2004, 07:11 PM   #6
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
I just got a 16' articulating ladder that lets you bend it into a 4' high 8' long scaffold. You have to put something on the rungs as a scaffold plank. It works well and is steady. I got mine from the local Ace hardware for $159. I don't think it would be good for full-timing like Porky is doing since it it is approximately 4'x1'x1.5' when folded for storage.
I forgot to give the name and model - ClimbTec CT416
Dennis
cosmotini is offline   Reply With Quote
Old 04-24-2004, 07:51 PM   #7
Davydd's Avatar
Tonka Bay
Images: 13
Xtend Telescoping Ladder
I've been looking for a ladder we can keep in our house to reach a storage loft and the skylights in our ceiling. It would double as an accessory for the trailer. What I found is the Xtend telescoping ladder that compacts to 30" and telescopes out to 12-1/2 feet.
Davydd
2015 Sprinter Class B Camper Van
(Former 1971 vintage Airstream Owner)
Davydd is offline   Reply With Quote
Old 04-25-2004, 12:35 AM   #8
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
I haven't gotten up the nerve to walk on mine.
I have a 16' alum. extension ladder(only need to extend a few feet) that I c-clamp a wood board to the ladder at the height to exactly match the awnings. Then I have a scrap piece of indoor carpet that I place between the wood board and the awning. I also made a leaning board covered with carpet that will more than hit two roof trusses. I use it to lean out over the top of the ladder if required.
I once saw an airstream where someone had forgotten and put their weight in between two trusses. Not very pretty!
wingfoot321 is offline   Reply With Quote
Old 04-25-2004, 02:59 AM   #9
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Hi Carol,
This is where I'd planned to pick it up again. You're in much better shape than most of us to be standing on your roof top.~lol
Just remember to follow the recommendation of ctdair, stay on the rivet lines..not that it's an issues for you but, I do believe there's a weight limitation of 200lbs as well. You should be fine once up there. Just don't step on the skin area between the rivet lines. Lean your ladder against the main awning rail, this should be the best place for getting on and off the top of your unit. I'd highly recommend that you never do anything up on top without having another person on the ground to steady the ladder for you~!! At the very least, they can pass things back up to you..
You might want to check out Wal Mart for some long handle tools for washing and, to reduce your longer reaching efforts while up there. Hopefully, you've purchased these.
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 04-25-2004, 07:38 AM   #10
norbert's Avatar
1993 30' Excella
chicagoland , north of cheddar curtain
Images: 24
hey, im too heavy! and i wouldnt trust any of those ladders any farther then i could throw them.... im afraid for my airstream not the height!...so any of you sparrows out there want to volunteer some of your time, i be glad to take you up....
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
roof vents larrylisa Roof Vents, Skylights & Fans 10 12-28-2009 04:22 PM
Getting on top of it uwe Audio, Video & TV 9 09-25-2006 12:28 PM
2004 30' Classic roof rack gklott Our Community 0 07-15-2003 03:00 PM
Roof question Don in E Texas Roof 2 02-21-2003 06:11 PM
Roof Air Problams ViewRVs Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 06:40 PM
