01-29-2014, 02:15 PM
huntingdon
, Pennsylvania
tv antenna removal
i want to eliminate the tv antenna and just put a square patch over the opening.
what sealant should i put on the patch or around the hoel of the patch before i rivet it on?
thanks
01-29-2014, 02:52 PM
2008 27' International FB
Venice
Sikaflex was recommended by my dealer mechanic, works great lasts long.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
01-29-2014, 04:23 PM
1965 22' Safari
Shelter Island
, New York
instead of patching the hole, you could consider using it to install a different kind of port, like cable TV.
Come on a (1965) Safari with me!
01-29-2014, 05:24 PM
huntingdon
, Pennsylvania
well right now water is leaking from it ...i think its going down the inside skin and coming out on top of the vistas view window opening so i was just going to patch it.... i think the vent is leaking too... i was just going to re seal everything on the roof... the floor also had a hole in right in front of the couch and on the door side.
01-29-2014, 05:31 PM
1976 27' Overlander
Tampa
what year is your coach?
Are you sure its not your Vista Views leaking? Simple fix to those is vulkem around the glass where it meets the plastic lip of the gasket. I actually cut the lip off and put a nice bead around it.... no more leaks there for me.
I can tell you that anywhere you "think" you have a leak, might be something totally different. I've been chasing leaks in my empty shell for 3 months. Raining tonight and found more..... Most were the rivets from shell to each rib on the roof. Some were the Vista Views. Surprisingly, not many are the windows/ doors or vents.
01-29-2014, 06:21 PM
1978 25' Tradewind
Metro Phoenix
My antenna leaks, too. However, I have a new-in-the-box old stock replacement crank up antenna. My plan is to take off the TV part, and use the elevating arm to mount a couple of YAGI long-range WiFi antennas. Like so:
Amazon.com: Superbat 16dBi 2.4GHz Wifi Yagi Antenna with RP-SMA Male Wlan Long Range: Electronics
"Between what matters and what seems to matter, how should the world we know judge wisely?" - E.C. Bentley, Trent's Last Case
01-29-2014, 06:43 PM
huntingdon
, Pennsylvania
its a 1974 , and i think one of the leaks is the vent cover it must have blew off and some one put a piece of plexiglass on it... i will have to see if i can seal the vista windows up
we probably wont be watching much tv to even worry about an antenna
thanks for the info
01-29-2014, 08:30 PM
1976 27' Overlander
Tampa
If you're talking about the plexi in the middle of the vent cover... I think that's factory. I have 2 with plexi middles and one that is solid aluminum. The PO taped up the plexi because they are rotted and cracked. That said, they still leaked, but I think you'll find that the plexi vents will leak straight down... i.e. not inside the skin. It cant go inside the skin because of the way it mounts. However if the vent "frame" is leaking it could head down the inside of the skin.
If your antenna isn't leaking, you might just leave it in case you, or a future owner wants to use it. Those old skyliner antennas still work well.
03-28-2014, 04:13 PM
1973 23' Safari
Brevard
We would like to use our original antenna but we can't find where it comes into the interior. We have looked all over. Any ideas? 1973 safari 23'.
If we rip it off, where can I get a piece of aluminum to cover the hole. Home Depot used to carry it but it no longer does.
Lexxy
After circumnavigating on 40' sailboat, cruising the USA in our '73 Safari, Tara!
03-28-2014, 04:29 PM
1975 31' Sovereign
Palomar Mountain
Lowe's carries aluminum in small sheets.
03-28-2014, 04:32 PM
Hollis
, New Hampshire
Vintage trailer supply has small sheets either 48 by 24
or 24 by 24
Aluminum Sheet 2024-T3 .032 Alclad - 48" x 24"
03-28-2014, 05:57 PM
Lin
, Ne
thanks
I used Vulkem in a caulking tube that I got from Fastenall.
03-28-2014, 07:59 PM
1976 27' Overlander
Tampa
aircraft spruce sells small pieces of matching .032 Alclad 2024 T3 for cheap. I just patched mine.
03-28-2014, 09:30 PM
1973 23' Safari
Brevard
Thanks a bunch. No home center near here sells it so I will order some. We don't watch tv anyway! Fortunately the little flat screen tv on a bracket that came with the unit plays DVDs!
I do plan to use vulkem. Should I sand the top and patch so it has tooth for the vulkem to hold?
Lexxy
03-28-2014, 09:32 PM
1976 27' Overlander
Tampa
Not necessary. Just clean is good.
