Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 06-02-2006, 07:50 AM   #15
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Not a pretty sight. Part of the reason I will be going with all new running gear. New axel, old one is original 1966, new brakes, current ones work but are questionable, and new rims as I have three right now but none match (?). Tires are cheap maintenance every 2 years and I will rotate to my flatbed trailer for the rest of their life.
Hope the damage is all repairable and yopu get back on the road soon.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 06-02-2006, 10:14 AM   #16
Leipper
Profile:
There was an idea floated a while back to have the feds put expiration dates on tires - 7 years. Conservative estimates run only 3 - 5 years.
It is the sitting that is one of the big problems with trailer tires. Some of the stuff that is in the rubber needs to be worked with in-use flexing in order to reduce age effects.
A study I have seen indicates that sunlight exposure was not the primary problem. This was based on the fact that the inside tires of duals had the most problems.
The biggest cause of tire failure is lack of air pressure. Keep them inflated to sidewall max cold rated PSI.
A lot of older Airstreams will show wheel well and skin damage from blowouts. It is one thing to look for if purchasing an older trailer.
Bryan
Leipper is online now   Reply With Quote
Old 06-03-2006, 10:05 AM   #17
Nye Thatcher
Nye Thatcher's Avatar
Profile:
I thought I would pass along some informatation as the tire looks like a Marathon. I know of two cases where Goodyear have stood behind the tire and repair. Your tire might qualify. Worth a try. GOOD LUCK
Nye
Nye Thatcher is offline   Reply With Quote
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
dual wheel tire pressure jpurdy Tires 2 10-14-2006 11:03 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Tire opinion Dbraw Tires 12 11-25-2002 07:39 AM
Blowout John Brimer Airstream Motorhome Forums 3 08-27-2002 05:15 PM
