Old 09-10-2002, 12:28 PM   #1
hex
hex's Avatar
Question Standin' on the Top of the Trailer
Standing on the roof!
Sure obviously you can, ~~But Should You Ever~~??
I know I know....Never At Highway Speeds...
But seriously now, it seems that access to the top would on occasion be necessary, right?
Are there certain "marked" areas to stand or kneel or lay? Probably Not!
Are the rivet lines always over a support strut (joist/rafter).
What is the on-center spacing of the ribs,struts? Is this always dead on on all models of Airstream trailers.
Are all support struts equal? i.e. some end over doors and windows, thus not carring load alway to floor I suspect.
Actually I have very little idea of the skeletal system of the trailers. Any idea where there is a good diagram. I am expecting to buy a 1974 Excella-31.
Is a mistep an instant dent? I weigh 222 lbs. naked.
Guaranteed heavier if on roof of anything.
hex is offline   Reply With Quote
Old 09-10-2002, 01:09 PM   #2
LOST , Hawaii
Sooner or later you have to get on the roof. I have spray foam insulation which substiantially strengthened the skin, but would not walk between ribs (vertical rivet lines). I think in the right place it would kink and be impossible to get out.
The horizontal rivet lines are panel joints, stay off them. The rivet lines that end at windows are still safe, the shape of the rib is what gives it strength even thought it doesn't make it to the floor. There is really no specific on center dimension, it is related to windows, doors, etc. Watch the rivet lines.
Ribs This is a link to my interior before it was insulated. The flat rib above the window I added, the others are Airstream originals. You can see how it curves up, and helps support the ac.
When you get on the roof use a padded board or piece of plywood (no scratching) and span 2 ribs. I measured them at one time, it seems to me the widest was 42" so it is not all that far. Pad your ladder where it will touch, be careful on the curves and you will be fine.
John
74Argosy24MH is offline   Reply With Quote
Old 09-10-2002, 02:16 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We've been told it's okay on the "flat" panels but not on the curved ends. John's advice of using plywood to disperse the weight is also recommended, using a thick moving-type blanket to protect the surface from scratches. Also, don't do it naked...the sunburn reflecting up from that shiny trailer will kill you!
Shari
Old 09-10-2002, 05:01 PM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I used the straightest 12' 2X4's I could find then screwed 2X4's appx 3' long perpendicular to them. This made it look like a ladder but missed areas such as the AC and vents. I then stapled pieces of carpeting around the long 2X4 where the ribs of the trailer ran underneath the skin. I was worried that when I used the wood screws that the long 2X4's would raise up causing an edge that would crease the trailer skin. That wasn't a problem because the only contact was on the ribs and the carpeting raised the rest of the 2X4 off the aluminum even while standing on it. Last, I layed sheets of 1/2" plywood on top of the 2X4 frame and slid them around to where I needed to sit or stand. I had scaffolding on one side of the trailer and ran two 2X4's with a plywood plank from there to the plywood sheets. It worked out great. I was afraid if I placed a thick blanket on the skin first and then a sheet of plywood, I would be thrown to one side or the other. The group is right, stay off the ends.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 09-11-2002, 04:09 AM   #5
1993 29' Excella
Jonesboro , Louisiana
Go to Airstreams' web page for a pictorial tour of a trailer under various stages of construction. You can see how the ribs,etc are istalled.
James Schmidt
29 ft Excello 1000
97 Expedition/Hensley Hitch/
McKesh mirrors
James Schmidt is offline   Reply With Quote
Old 02-04-2009, 10:20 AM   #6
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Yes sir, that "HEX" was quite a guy..You just had to admire his sense of "humor"..
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 12-05-2009, 03:53 PM   #7
Airstream01's Avatar
2008 25' Safari FB SE
Land of fruits and nuts , California
reviving a thread. I've been on my roof once to wash it and remove leaves, pine needles, etc. I got up with a step ladder (with the girl holding it so I didn't bust my @$$) and pretty much stayed on all fours over ribs only, or layed down on my belly. Hope I didn't hurt nuthin'
Airstream01 is offline   Reply With Quote
Old 12-05-2009, 04:14 PM   #8
1960 24' Tradewind
Riverside , California
I'm 290 and on the roofs quite alot, stay on the rivet lines....no damage yet.
Greg
ZoomZoom is offline   Reply With Quote
Old 12-05-2009, 04:44 PM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
A "Little Giant" type articulating ladder can have the top section angled so that the end rests near the roof center. I glued carpet with contact cement to the areas on the ladder which come in contact with the skin to avoid scratching.
Old 12-05-2009, 05:59 PM   #10
Master of Universe
Gene's Avatar
Grand Junction , Colorado
I guess hex fell off the roof in Feb. 2003. That was his last post.
Gene
Old 12-05-2009, 06:54 PM   #11
Images: 59
Could it be?
More likely I think he crossed swords with the wrong person.
markdoane is online now   Reply With Quote
Old 12-05-2009, 07:18 PM   #12
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Pics?
Are there any pictures posted of the devices that have been made for roof work? I am more afraid of losing my balance and denting the aluminum than I am of falling off the roof. If push came to shove, I think I'd jump. Maybe I'll try telling my wife how graceful she is, and how clumsy I am.
I've got it! I have a tower for my ham radio. I'll park the trailer beside it, and lower myself down from the tower. Has anyone tried that under a big tree?
Regards,
Ken
Old 12-05-2009, 07:35 PM   #13
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Here is a simple setup made by Zeppelinium. It's a ladder up each side with a pad to protect the skin on the sides of the trailer. Across the top a 2X10 is secured to each end. The two ladders are roped together above and below the trailer.
That's me at the 4CU Restoration Rally working on the hole for my new air conditioner.
Richard
Old 12-05-2009, 07:41 PM   #14
Ag&Au's Avatar
Thanks Richard,
What were you kneeling on?
Ken
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 08:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 08:05 AM
Top ten things about rebuilding a new trailer campcollector 1997 - 2004 Bambi 2 02-27-2004 04:56 AM
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 01:43 PM
Getting Close! kamadeca Our Community 48 02-05-2003 08:56 AM
