Old 11-01-2011, 04:53 PM   #1
la nomade's Avatar
2018 22' Sport
stanfordville , New York
Solar panel
here is a solar panel on top of the front airconditioner......can not figure out what it does nor how it woks if it does?????any ideas????
la nomade is offline   Reply With Quote
Old 11-01-2011, 05:42 PM   #2
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
A Few Questions
IS there a wire pair running from the panel to the refrigerator vent cover?
Is the other end of this wire visible in the exterior access compartment to the refrigerator?
Is there a junction or solar controller in the refer access compartment?
Is there a solar controller anywhere inside the coach?
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 11-01-2011, 06:00 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Any solar panel that will fit on a roof top air conditioner will only give you a slight trickle charge to your batteries....perhaps just under 1 amp at best (if that much). For the effort required to connect it and run charge wires to your batteries, IMHO, it is hardly worth the effort for the slight return that you may or may not get..depending on the condition of the panel.
Old 11-01-2011, 06:27 PM   #4
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 55
If you have a Penguin Low Profile, you can try this.
The 40W monocrystaline panels are too big so you will have to use a 40W polycrystaline. (see post for size details)
http://www.airforums.com/forums/f313...ml#post1021953
The roof is only so big, so you have to use every area possible.
Dave
Old 11-02-2011, 11:23 AM   #5
la nomade's Avatar
2018 22' Sport
thank you,no wires that i can locate...i may as well let it be since it would not or is not giving me much energy anyway...i am the 3rd owner,the 1st owner probably put it on...
Old 11-02-2011, 11:27 AM   #6
la nomade's Avatar
2018 22' Sport
i will simply forget about it...thank you...it was probably installed by the 1st owner,i am the 3rd one...happily so..
Old 11-02-2011, 11:29 AM   #7
la nomade's Avatar
2018 22' Sport
thank you,it all sounds much too involved for so little energy generated...i will, simply forget about it,knowing now what is what....very helpfull...
Help my solar controller caught on fire bmklawt Generators & Solar Power 28 03-24-2016 11:02 AM
Solar Panel Question marvinr Generators & Solar Power 2 09-20-2011 04:06 PM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
Roof mount Brackets for Solar Panel Bo2020 Generators & Solar Power 2 04-11-2011 01:20 PM
Solar Panel Prices Dropping tbro Generators & Solar Power 11 03-30-2011 08:21 PM
