Old 05-08-2016, 06:03 PM   #1
1972 27' Overlander
Lamar , Missouri
Size patch?
Removing old winegard antenna. There are 32 holes where the antenna was. Is that a record?
How much should patch extend from the holes? Maybe 1 inch?
Also, what is the number of rivets to put the patch on? Maybe three per side? I really don't want to drill more holes in this roof!
ID:	262165   Click image for larger version
walleye001 is offline   Reply With Quote
Old 05-08-2016, 06:33 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Standard ED (edge distance) is 2-4 D (diameter of rivers to be installed). Standard Rivet spacing is 6-8 D
Old 05-09-2016, 09:00 AM   #3
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
I like to go past the holes at least 1/2 inch with rivets 2 inches apart with sikaflex on all the previous holes and sikaflex on the new patch!
Matt
rugjenkins is offline   Reply With Quote
To patch or not to patch... truckirwin Repairing/Replacing Floor &/or Frame 8 05-01-2014 05:18 AM
Body mods: To patch, or not to patch? Belegedhel Ribs, Skins & Rivets 0 01-05-2012 09:33 AM
Wanted: A/S clothing patch tin can luv Commercial Listings 6 03-10-2004 08:33 PM
Water line patch, or factory? TomW Fresh Water Systems 5 12-29-2003 10:14 AM
How do you patch Bullet holes? 59toaster Ribs, Skins & Rivets 5 10-26-2003 08:08 PM
