Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 02-21-2003, 03:45 PM   #1
Don in E Texas
Don in E Texas's Avatar
Profile:
Question Roof question
I want to remove the current TV antenna from the roof of my 1987 31' TT. In its place I plan to install a satellite antenna (it will not fit over the current opening in the roof - too close to the front vent).
My question is about the roof. The new satellite antenna should be mounted in the center line of the roof. Is there a main structure beam in the center that would cause a problem? And can the roof be walked on?
My current motorhome (bus conversion) does have a center main support - the satellite antenna is mounted just to the side of center. The roof can be walked on w/o any problem (heck, you could dance on the roof!)
Thanks for any insite you may be able to share.
Don
Don in E Texas
Don in E Texas is offline   Reply With Quote
Old 02-21-2003, 04:09 PM   #2
74Argosy24MH
Profile:  LOST , Hawaii
No center support. The vertical rivet lines on the outside are ribs that go up and around. Don't dance on the roof, you will end up in the basement. If you need to get on it use a piece of padded plywood spanning the ribs, it is pretty thin. The picture is looking up in my mh, will give you an idea of what is inside.
John
74Argosy24MH is offline   Reply With Quote
Old 02-21-2003, 07:11 PM   #3
Don in E Texas
Profile:
Thanks!
Just the information I was looking for!!!
Thanks!!
Don in E Texas
never been on the roof whistler Roof 20 08-22-2005 09:26 PM
Fantastic Fan question flyfisher Roof Vents, Skylights & Fans 8 09-11-2003 06:18 PM
Another newbie question... fan on roof??? flamingo-kid1 Roof Vents, Skylights & Fans 5 07-27-2003 10:12 PM
2004 30' Classic roof rack gklott Our Community 0 07-15-2003 04:00 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 02:35 PM
