Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 09-15-2007, 11:38 PM   #1
flyguy
Profile:  2006 19' Safari
Flagstaff , Arizona
Roof Hatch
Hi everybody,
We have a 2006 Safari 19' Bambi and when we were out the last time I noticed that the rear roof hatch was broken. This is the hatch that is over the bed. The hatch had broken off of the raising and lowering rod. I called a local RV repair place and they wanted to know what size the hatch is. They didn't tell me how to measure it. The size of the opening is 12" x 12" but I'm not sure that that is the right measurement. I know that the plastic part that opens and closes needs to be replaced but I bet that the whole assembly does not need replacement.
The other thing is how do I know if a place is reputable or not? I would like to find someone local to go to since the dealer where I bought our Bambi is about 3 hours away. Your thoughts and direction are always appreciated.
Flyguy
flyguy is offline   Reply With Quote
Old 09-15-2007, 11:43 PM   #2
BIGED52
BIGED52's Avatar
Profile:  1967 22' Safari
MILAN , Illinois
hatch
Why not call the factory at JC and see if it is covered by a warranty? In either case I do think that the cover is the only part you need and that A/S Parts dept will have that item in stock. Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004
AIR#7110
"My tire was thumping, I thought it was flat!
When I looked at the tire... I noticed your CAT!"
Burma Shave
BIGED52 is offline   Reply With Quote
Old 09-16-2007, 04:14 PM   #3
TBRich
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
Flyguy...the dome on our non-fantastic vent (over the bed) of our 2006 19' Safari Bambi had to be replaced as well...it was cracked where the lifting rod attaches to the plastic dome on the back side (the side that lifts up)... it was replaced under warranty...as should yours. We had the work done at Oasis RV Center (Airstream dealer in Tucson...(800) 658-5863)...they will know exactly the size you need and I am sure they have them in stock...and they are reputable. I don't think it's a difficulat repair to make.
TB
Old 09-16-2007, 05:16 PM   #4
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Just a thought...............
Instead of replacing the dead vent over the bed, why not add a Maxx-Air or Fantastic fan. You wouldn't believe the extra ventilating power that you get with 2 powered fans....one bowing out and the other blowing in
I have 2 Maxx-Air fans and use them in the push-pull mode often. The nice benefit of the Maxx-Air over the Fantastic is the ability to use it in the rain, as the cover simply hinges up, but stays in place to prevent water from entering the trailer.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 09-16-2007, 05:27 PM   #5
Kevbo10
Profile:  2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley , California
i'm not a big fan of Fantastic Fans right about now... ever cleaned the whole asembly?
kevin
Name:	fantastic fan 01.jpg
ID:	45478   Click image for larger version
Name:	fantastic fan 02.jpg
Kevbo10 is offline   Reply With Quote
Old 09-16-2007, 05:37 PM   #6
lewster
Commercial Vendor
lewster's Avatar
kevin
One more nice feature of the Maxx-Air fans. The inner screen assembly is secured by 4 spring loaded clips that swivel out of the way. Takes about 2 seconds each for easy access to the blades for cleaning.
AIR # 10325
Old 09-16-2007, 06:57 PM   #7
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
I put one of Inland's Solar domes on the rear vent in our coach, it was very easy to do. I also replaced another vent with a Fantastic, that install went well also. Front and rear vents have Maxx-air covers, the rear one has no fan in it, but I like the fact I can leave it open in the rain. In fact, I leave front and rear vents open when not using the trailer, it keeps it from being quite so much an oven.
Old 09-16-2007, 11:20 PM   #8
flyguy
Flagstaff , Arizona
Thanks everyone for your suggestions. I think that I will replace the entire vent and go with the Maxx-Air setup.
Flyguy
Missing Hatch Cover bevman Exterior Storage Compartments & Access Doors 4 03-19-2008 01:50 PM
Outside Hatch Doors Joey 73 Exterior Storage Compartments & Access Doors 2 04-10-2006 04:56 PM
Hatch hinges ralley Classic Motorhomes 4 03-15-2006 07:34 PM
Hatch gaskets... Sneakinup Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 01-26-2004 10:09 AM
