Old 05-26-2013, 10:35 AM   #1
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Roof dents appearing
Hey all,
I just finished a rear end separation rear about 6 months ago. On our camping trip this weekend, dents are appearing on the roof around the area of the AC unit. When the sun goes down and the metal cools down the dents go away. I had put some jack stands under and thought that might have been the problem. Now it's just still n 4 wheels and the tongue jack. Any ideas?
ID:	186562   Click image for larger version
Silverflames is offline   Reply With Quote
Old 05-26-2013, 10:58 AM   #2
1981 31' Excella II
New Market , Alabama
I expect someone stood there and bent something a little and it pops out when it cools off. Not much you can do from the outside.
Perry
Old 05-26-2013, 11:17 AM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
You know, we had some of those near the AC on our 67. You can easily pop them out with a toilet plunger, but they just pop right back in. So I thought and thought and thought. Considered expanding foam inside the wall, but that's hard to control and could wind up doing more damage than good. And finally came up with an alternative: I bought some small springs from the hardware store, removed some interior rivets below the dent, and wound the springs into the rivet holes just enough to put some mild push upward on the dent. Cut off excess spring, push through the remainder, and reinstall the rivets.
Lynn
WBCCI 21043
Old 05-26-2013, 02:45 PM   #4
1969 29' Ambassador
Lynn
Would your dents come and go with the heat?
Old 05-26-2013, 02:56 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Nope, they just kind of stayed put. On the other hand, we don't exactly get a lot of hot days here.
Lynn
WBCCI 21043
Old 05-26-2013, 06:11 PM   #6
1988 32' Excella
Robbinsville , New Jersey
The aluminum may have been stretched by someone walking on the roof and/or the rear end sag that you repaired (back of trailer being held up by roof).
Some have complained about the same thing (dented/warped when warm/in sun fine when cool) on the sides of new Airstreams, others have no problem with it. My theory/guess is the new trailers with this problem were built when the factory was colder so the aluminum was contracted when cut to size and riveted in place.
Old 06-03-2013, 10:21 PM   #7
1969 29' Ambassador
Perry
Yea after the roof cooled, looking closer there is is two slight dents there. They just look much worse when the metal is heated up. I also cut out a 14 " hole and framed it in for the AC in that's area. The top is rounded, except for the AC section and it is forced straight. I wonder if that could be making the problem worse?
Old 06-14-2013, 01:26 PM   #8
1969 29' Ambassador
Ok guys and gals, I might be way over thinking this thing, and making myself crazy. I measured the rear frame of the bumper truck area, were I replaced the frame to fix the rear end separation. It appears that there is about a .25" difference from the driver's side and the passenger side (after being bolted down). I measured from the top of the frame for the bumper trunk to the bottom of the aluminum skin. It looks like the curb side is a little lower. It's not much right under the rear trunk area, but gets larger further you get closer to the edge of the trailer. You can't even notice with the naked eye.
I measured from the ground, and there was about a 3/8-1/2 (uneven ground) height difference from the bottom of the frame rails. Could this much of a difference be causing the body to twist in the heat? I have been trying to image how a slight twist (one side being to high or to low) could effect the shell, and cause dents in the middle of the trailer on the driver's side, and 3/4 of the way down on the curb side.
Only to make things more colluded, while repairing the rear frame, I set the bathroom on fire. So there may also be some heat damage. But that is nowhere near the AC and middle part of the trailer.?...
Also It should be noted that while I have the trailer back in shade the dents are pretty much gone.
Well any thoughts would be great. I'm hesitant on moving forward with the flooring and new bulkheads.
Old 06-14-2013, 01:37 PM   #9
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
When you did your rear frame repair/replacement, how much beefier did you leave the frame? One proposed explanation I would have is that once the (original) frame and shell form a unit, the whole thing is engineered to expand and contract at roughly the same rate.
Perhaps you have beefed up the rear of the frame so that it no longer expands and contracts at the same rate as the shell, or maybe, you have stiffened it up. When the shell gets hot, instead of the entire trailer growing a fraction longer, maybe the shell is expanding further/more rapidly than the frame in which case it is causing the roof to buckle, since it has nowhere to go.
I might soon have the same problem, as I stiffened up the rear of my frame during a RES repair as well.
good luck
Old 06-14-2013, 01:41 PM   #10
Belegedhel's Avatar
Houston , Texas
If you still have access to the bolts that attach the rear C-channel to the subfloor, you might try loosening them up and see if it makes any difference--just for the sake of experimentation. You might also try standing on the rear bumper when the dents appear and see if some weight back there helps stretch them out.
Old 06-14-2013, 01:44 PM   #11
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The aluminum probably stretched some with the rear separation, and you have pushed it back with the repair.
Aluminum expands and contracts with the heat of direct sunlight and shade. Our new Airstream "oil cans" in the sun. The least of our concerns.
If this is the problem, and it probably is, I wouldn't lose a wink of sleep over it.
doug k
Old 06-14-2013, 02:33 PM   #12
1969 29' Ambassador
good luck
Yea, I am the master of over kill. Every part of the main frame rail I have replaced has been with galv 1/4" thick 5" tall C channel, and I added 3" more inches of depth to the frame from the back wheels to the trunk area. So the the frame is pretty ridged 8" tall. All tied together with 1/2 " SS bolts.
You bring up a good point about the frame not expanding like the rest of the body. Possibly compounding with the body that has been stretched from years of a giggly lose back end. That is much more likely to cause the dents than the body being twisted. I'm guess I'm just worrying over nothing here. Loosening the bolts and setting it in the sun is a good idea.
Old 06-14-2013, 02:46 PM   #13
1969 29' Ambassador
I just wanted to add a pick of the frame.
The second is before I bolted it down.
ID:	188262   Click image for larger version
Old 07-08-2013, 09:36 PM   #14
Belegedhel's Avatar
Houston , Texas
Looks like good work--quite burly! Do you notice any other (possible) effects of a more-ridgid-than-original frame (ie., popped rivets, skin cracks, etc.?
