Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 05-15-2006, 07:34 AM   #15
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Airstream, if you brought it to the factory might just put panels over the damaged ones rather than remove and replace.
Old 05-15-2006, 09:05 AM   #16
dmac
Profile:  2003 25' Safari
Eden Prairie , Minnesota
If it were mine I would:
- Order a new center segment
- Drill out the rivits
- Remove the old segment (more difficult than it sounds because of the sealer)
- Carefully work out the dents in the adjoining segments
- Install the new segment
Dan
dmac is offline   Reply With Quote
Old 05-15-2006, 10:31 AM   #17
Silvertwinkie
Aluminut
I'd probobly want it done the same way dmac has listed, maybe even replace both side segments depending on how bad it looked after trying to smooth them out. I'm not a real big fan of doubling up the sheetmetal, but I'm also a bit uneasy about disturbing the factory sealing that is done from the inside.
Anyway you go though, there is no inexpensive fix.
Old 05-16-2006, 01:26 AM   #18
scottanlily
Profile:  1960 24' Tradewind
santa barbara , California
I would get it repaired properly ,dont fool around ,lots of good ideas here on the forums.If insured ,then take it to the best facility with the best reputation ,after all that is why you have insurance .You will be happier when you know its as good as new.
Scott
scottanlily is offline   Reply With Quote
Old 05-16-2006, 06:56 AM   #19
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
Originally Posted by Denis4x4
Still need some referrals as to who can get the job done.
Oasis RV in Tucson. I saw the work they did on one backed into a garage and you would never know. Don't expect much when you see the place, but they do great work.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
dull roof on 1986 31' sovereign Daryl Miron Roof 12 07-25-2005 01:37 AM
Roof Air Problams 1985air345 Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 07:40 PM
roof stack gaskets bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-25-2002 06:29 PM
Roof coating FrankR Roof 4 07-22-2002 02:56 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 02:35 PM
