Old 06-04-2010, 07:22 AM   #15
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
Roof Sealer - Heat reflector...
For those interested, here's a shot after I applied the recommended two coats of the material...
Good luck!
Art
Name:	Sealoflex Application.jpg
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Old 06-18-2010, 03:55 AM   #16
1976 29' Ambassador
1997 34' Limited
Cornwall , Ontario
Ceramiflex
WHERE CAN I PURCHASE THIS PRODUCT? I HAVE A 34', HOW MUCH IS NEEDED TO DO THE ROOF?
Ken Scott is offline   Reply With Quote
Old 06-18-2010, 05:04 AM   #17
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
You can figure about a gallon per coat on a 34'. I put three coats on and had about 2 gallons left in a five gallon container. Not sure where you can find it in Canada.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 06-18-2010, 06:06 AM   #18
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Ceramiflex is made by Sealoflex. If it is not available locally you can get it from the factory. The factory only sells 5 gallon containers. However, the factory will ship a product they call Final Coat in one gallon containers. Factory says it has similar properties.
In contrast to thread above, the factory says acid etch primer should be used first. They also sell that in gallons.
Old 06-18-2010, 03:39 PM   #19
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
The factory is contradicting its own Data Sheet on the product then--wonder why?
http://www.sealoflex.com/files/pdf/Ceramiflex.pdf
Bill Cantrell
AIR 24338
TAC SC-1
Old 06-18-2010, 05:19 PM   #20
Lumatic's Avatar
1993 34' Excella
Images: 16
To sell me another bucket of paint perhaps? Anyway I bought, I don't want to do the job again in a few years if the paint does not stick.
Old 06-20-2010, 09:07 AM   #21
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
I ordered my 5-gal bucket (smallest size they ship) right from the factory...
Used less than a gallon for two coats - recommended application. You definitely need the second coat to cover the first layer. Three might be too much...
Their contact info:
SEALOFLEX INC.
2520 Oscar Johnson Dr.
Charleston, SC 29405
Tel: (843) 554-6466
Fax: (843) 554-6458
Toll-Free: (800) 770-6466
Good people to deal with. Got the material quickly, albeit paid heavily for the shipping costs from SC to NM...
Good luck...
Art - W0ABX
'85 Sovereign 25'er
Old 06-21-2010, 07:45 AM   #22
Lumatic's Avatar
1993 34' Excella
Images: 16
Spoke to Sealoflex again today. The guy I spoke to this time said the metal etch primer might not be necessary. Suggested doing a "pull test"- use the paint to glue a piece of drywall tape to a section, let it dry, and try to pull it off. It it pulls, you need the primer. Said the primer couldn't hurt though. But, I ordered the primer and it's on it's way.
Also the label on the Ceramiflex says 'not a substitute for final coat" The tech said Ceramiflex is part of a system for waterproofing. But if you are mainly looking for reflectivity you don't need the final coat.
He also said they don't sell much Ceramiflex. They sell more Reflectowhite.
Old 09-22-2010, 05:25 PM   #23
- , Ontario
Instead of Sealoflex product, I wonder if EPDM "liquid rubber roof" would fit your needs? For more details, surf:
EPDM Liquid Roof and Liquid Rubber - EPDM for Leaking Roof Repair
Spike99 is offline   Reply With Quote
Do you have rubber coating on the roof? dbtolman Roof 22 03-16-2009 04:29 PM
Removing black roof coating lessen Cleaning, Stripping & Polishing 1 06-02-2006 09:55 AM
removing roof coating airtim Cleaning, Stripping & Polishing 2 04-02-2005 09:43 PM
Powder coating - you can do it yourself! drboyd Clearcoat, Exterior Paint & Trim 0 07-01-2003 01:32 PM
Roof coating FrankR Roof 4 07-22-2002 01:56 PM
