Old 02-15-2019, 09:26 AM   #1
1973 31' Sovereign
Cottage Grove , Minnesota
roof brackets.
I was on the roof of my 73 landyacht covering up the broken vents to stop moisture intrusion before I begin the demo work. I noticed these brackets and have no idea what they are for. their are 3 of them total 2 on the left rear and 1 on the right rear. I know someone out there knows. Please clue me in. Thanks in advance.
gregg
Name:	airstrem roof picture.jpg
gfmeyer is offline   Reply With Quote
Old 02-15-2019, 10:03 AM   #2
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
Looks like a vent pipe (for gray & black water system) cover. Are they cast like these? https://www.vintagetrailersupply.com...p/vts-1081.htm
Harold & Rebecca
http://www.airforums.com/forums/f97/...er-172124.html
57Vintage is offline   Reply With Quote
Old 02-15-2019, 10:18 AM   #3
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
They are the vent pipe stacks for your year, polish up nice.
cole3444 is offline   Reply With Quote
Old 02-15-2019, 10:25 AM   #4
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Sewer vents
gregg
You mean the sewer vents?
SuperTrouper is offline   Reply With Quote
Old 02-15-2019, 10:34 AM   #5
1994 34' Excella
Warren , Manitoba
Those are the vents for your plumbing system. There is a rubber gasket under them that is probably cracked and must be replaced. The vents are ABS pipe and the gasket fits around the pipe. There is a drain on the bottom side of the cast cover that must remain open so that rain water can drain out and not into your tanks. Water can enter your trailer if the gaskets are bad and not replaced. Not a big cost or job. Available from Out of Doors mart or other Airstream suppliers.
WBCCI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 02-15-2019, 11:20 AM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Those vent either go to the holding tanks or are inline with the drain lines to prevent the "P" traps from being siphoned dry when water is flowing from the sink or other water devices. New gaskets are inexpensive and they are easy to replace.
Richard
Old 02-15-2019, 11:51 AM   #7
1973 31' Sovereign
thanks for the answers. As soon as it warms up a bit here in Minnesota the demolition process will begin. I'll post some pics. thanks again.
Old 02-15-2019, 12:49 PM   #8
2002 25' Safari
Dewey , Arizona
Images: 62
This is the gasket for the vent pipe:
http://odmrv.com/catalog/index.php?m...roducts_id=913
Richard
Old 02-15-2019, 01:40 PM   #9
1981 31' Excella II
New Market , Alabama
The gaskets are worse than useless. A good urethane caulk works as good or better. Better yet get some of the zinc plated steel vents from VTS and replace them with something that won't leak.
Perry
Old 02-15-2019, 04:29 PM   #10
1976 31' Sovereign
Oswego , Illinois
Thumbs down
Perry
Zink plated steel isn't good w/aluminum as cause of galvanic action that will destroy or severly harm aluminum IMO.
Old 02-15-2019, 05:57 PM   #11
1994 34' Excella
Warren , Manitoba
When you replace the gasket be sure to replace or install the screen over the vent pipe to keep bugs out of the system. I prefer the gasket over caulking as some of the gaps between the pipe and roof cutout are sometimes large, and you have a good seal. I replace my gaskets about every 5 years. Easy to do when resealing the vents stc on the roof
WBCCI #7394
Roof mount Brackets for Solar Panel Bo2020 Generators & Solar Power 2 04-11-2011 01:20 PM
Mounting Brackets for Folding Table?? Navigator Cabinets, Counter Tops & Furnishings 38 04-25-2008 10:50 PM
Need Window Awning Brackets RBolton Awnings 3 08-01-2007 12:13 PM
Awning Brackets - How to Attach to Trailer ? mr085949 Awnings 1 07-04-2006 09:29 AM
Attaching Awning Brackets Mike Rhodes Awnings 7 10-30-2002 07:35 PM
