Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 07-04-2009, 12:55 AM   #1
Foiled Again's Avatar
Virginia Beach , Virginia
It's science experiement time!
It MIGHT be tar. Try a hair dryer - or heat gun, but be careful. If it softens, take off as much as possible with a wooden or plastic scraper so as not to gouge the metal.
Some things soften with oil. Use a few drops of machine oil on one small area, wait 30 min. and see what happens.
WD-40. It works on so much, try a spot - again give it time to work - then try to wipe it off.
Aircraft Stripper - designed to take off clear coat. This stuff is wicked bad, but will strip a lot of stuff.
Well there is a starting list.
Good luck, Paula
Today is a gift. That's why they call it "the present"
Removing black roof coating tnessel Cleaning, Stripping & Polishing 1 06-02-2006 10:55 AM
Need help removing black/grey tanks baseballmamm Waste Systems, Tanks & Totes 2 08-13-2005 10:15 PM
Removing Black Holding Tank - Need Help! wayner1239 Waste Systems, Tanks & Totes 10 03-31-2005 11:04 PM
black rubber sealant looks like bacon dikku@mac.com Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 08-24-2004 07:26 PM
Removing Black water tank vishwa Airstream Motorhome Forums 6 09-08-2003 01:29 PM
