Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 10-21-2008, 05:11 AM   #1
Profile:  2005 22' International CCD
Woodland Park , Colorado
Removed TV Antenna...
to make room for future solar setup. Looking for advice on how to cover and seal the hole in the roof.
current plan is to cover with a piece of sheet aluminum. screws or rivets? also, what is the best sealant to use?
thanks for your help. jk
JK3500 is offline   Reply With Quote
Old 10-21-2008, 07:04 AM   #2
Silverhobby's Avatar
Profile:  1956 26' Cruiser/Overlander
1957 26' Overlander
1962 22' Flying Cloud
Vale , North Carolina
Be sure to use Vulkem or Trempro. A liberal amount under the patch, then seal either the rivets, or screw heads that you have used to secure the patch. I removed the antenna from my 1971 Caravel and used Vulkem. Best of luck to you.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 10-21-2008, 07:05 AM   #3
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Here is what I did, may help
I have since used Vulkem on the cover, works better than PARBOND
Leak
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 10-22-2008, 06:26 AM   #4
Leak
Thanks! That is pretty much what I was planning. Hadn't though of the spray-foam in the holes though. Will definitely do that. jk
Old 10-21-2008, 07:44 AM   #5
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
I "temporarily" covered the hole with a jar lid and just vulkem about 5 years ago. Out of sight out of mind.
Pay no attention to the man behind the curtain- WoZ
Lumatic is online now   Reply With Quote
Old 10-22-2008, 06:23 AM   #6
Sounds like the sealant of choice is vulcem. I guess I'll have to order some. Any thoughts on Sikaflex 221? I have two tubes of that... Thanks again, jk
Old 10-22-2008, 06:33 AM   #7
balrgn's Avatar
Images: 74
Go with the product you have. It works as well!
Member of VAC
www.balrgn.com
Old 10-22-2008, 06:55 AM   #8
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
TV Antenna????
I thought the thingy on the top of mine trailer was a high speed collapsible clothes drying rack...Now I know why I kept losing some many clothes between rest stops.
Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
Old 10-22-2008, 11:22 AM   #9
Jim Foster
Jim Foster's Avatar
Profile:  1965 17' Caravel
1983 27' Excella
Walnut Grove , California
If you use Sikaflex to attach the clothes to the rack, that may solve your problem........might save you stops at Costco for new undies.
Old 10-22-2008, 12:18 PM   #10
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
I thought it was a high speed type of spoiler... I had my wife riding in the trailer to crank it up when I hit 70 mph, to help stabilize the trailer at high speeds.
No wonder my wife said she got better tv reception at 70+ mph
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Removed the carpet! Santart Land Yacht/Legacy Motorhomes 12 09-13-2009 06:53 PM
Anyone ever removed the Frigerator? 911rs Argosy Motorhomes 10 09-12-2008 07:47 AM
Removed the door... gotohatteras 2006 Safari 7 06-30-2007 07:10 PM
Has any one just removed.... tyndalelady Upholstery, Blinds, Walls & Interior Finishes 4 01-26-2006 12:12 PM
Removed Vinyl from Door! tin can luv General Interior Topics 37 07-14-2004 09:09 AM
