Old 10-01-2011, 03:45 PM   #1
1981 31' Excella II
New Market , Alabama
Putting on New AC Shroud and Studs are all but gone
I am trying to put a new AC shroud on my old Coleman Mach 3 which is probably the original 1981 unit. I got what was left of the nuts off the studs but there is not much left of the studs. I was wondering what my options are.
I guess worse case I could put in sheet metal screws just behind or in front of the existing 1/4"-20 studs. I don't have the time or the facilities to remove the thing and install new studs and I don't have the time right now if I did.
The old shroud came off in pieces it was so rotten. I really did not even need to remove the screws.
Any suggestions?
Perry
Old 10-01-2011, 04:26 PM   #2
1988 32.5' Airstream 325
calgary , alberta
Hi where did you order your shroud from thanks Jonathan
jhenry is offline   Reply With Quote
Old 10-01-2011, 06:43 PM   #3
1981 31' Excella II
I got it from here and it does fit although the holes were a little off. You can always lengthen the slots or put in new holes.
http://www.pplmotorhomes.com/
Perry
Old 10-01-2011, 07:15 PM   #4
1981 31' Excella II
If I had a decent parts diagram, it would give me a good idea where I can and can't drill holes in the sheet metal. My knee is already screwed up and I am not sure how many more trips I can make up the ladder.
Perry
Old 10-09-2011, 07:39 PM   #5
1981 31' Excella II
Just to update what I ended up doing, I drilled new holes in the sheet metal where the original studs were located. On the back, I put new holes about an inch in front of the studs and on the front I put them about an inch behind the studs. I used some #10 sheet metal screws and some big stainless steel washers.
Perry
