Old 08-20-2017, 06:41 PM   #1
1995 30' Excella
Harper Woods , Michigan
Popular Mechanics scaffold for roof work.
Hi, I'll need to do roof work on a 30' Excella, so I'm going to build this scaffold as shown in the Popular Mechanics (Aug. '68,p.p164-5), (URL link below), and make a plank/work platform to bridge on to the roof. Any suggestions?
https://books.google.com/books?id=q9...caffold&f=true
I'm not interested in using a ladder. As former physiology/surgery prof, I know that the probability of serious (possibly crippling) injury or death from falling from the roof height of an AS is unacceptably high to me - 50% for injury, 25% for fatality.
http://www.ehstoday.com/nothing-easy-falling-off-ladder
Bob Blarney is offline   Reply With Quote
Old 08-20-2017, 06:50 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Why not just rent commercial scaffolding?
Old 08-20-2017, 07:06 PM   #3
1995 30' Excella
I expect that I'll be doing some painting on the windows, soffits, and eaves of the house & garage too. I think it'd be cheaper in the long run than renting or buying a 6-10' ft high scaffold.
Old 08-20-2017, 07:28 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Safety first. Whatever works for you.
MICHAEL
Old 08-20-2017, 07:55 PM   #5
1977 Argosy 24
Milltown , Wisconsin
Won't the trailer be in the way of the X bracing?
ventport is offline   Reply With Quote
Old 08-20-2017, 08:41 PM   #6
2015 30' FB FC Bunk
Ayer , Massachusetts
That's a Baker stage. Go to Home Depot you can probably buy one cheaper than the lumber, casters and hardware to make one.
I have a few of those but I can't reach the center of the roof. Also, they are basically a ladder to climb up on.
Ted S. is offline   Reply With Quote
Old 08-20-2017, 09:45 PM   #7
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
I'm renting again this year, even up here in Canada it's only about $80 a month for a 10' long 5' wide 6'6" tall unit on lockable casters.
truckasaurus is offline   Reply With Quote
Old 08-20-2017, 11:13 PM   #8
Mollysdad's Avatar
I'd rent a scaffold for both sides and design a bridge over the AS.
Then you never have to get on the roof.
Old 08-21-2017, 06:42 AM   #9
1995 30' Excella
The Baker scaffolds available nearby are a max height of ~6ft and cost ~$180 ea minimum, and the rental price for one (min two needed) is $125-150/wk. The materials cost for this wooden one is about $100, and would take about one morning to build. Many of the features of the storebought ones (e.g. 2" incremental adjustment, locking casters, adjustable leg lengths) are not needed. A wooden one might actually be safer because it's not slippery, and rails, platforms, shelves, and other accessories can be screwed in place anywhere as needed.
Old 08-21-2017, 07:26 AM   #10
2016 25' Flying Cloud
Holly Springs , Mississippi
Mollysdad has the better answer, if you want to use scaffolding.
Personally, I found my ladder the better solution. It's a 14 foot extension ladder (not a folder), with a foam-padded 4 foot horizontal board attached to the ladder where it contacts the side of the trailer. The board is long enough to be supported by the vertical ribs of the trailer. It's very easy to get on top, but then what? I made a flexible platform -- padded with rubber shelf liner -- from 1 X 4 boards connected together by 1" nylon straps, with an inch between the boards. Thus it conforms to the curve of the roof, won't slide around, and is supported by the roof's ribs. I'm going to upgrade it by putting anti-slip strips on the top of the boards.
Scaffolding is the better answer if you need to work on the full length of the trailer. Just work on a section, get down and move the scaffolds, and go back up. But again, I think scaffolding on just one side requires a bridge to the roof.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 08-21-2017, 07:53 AM   #11
1995 30' Excella
Bob662: I made a flexible platform -- padded with rubber shelf liner -- from 1 X 4 boards connected together by 1" nylon straps, with an inch between the boards. Thus it conforms to the curve of the roof, won't slide around, and is supported by the roof's ribs. I'm going to upgrade it by putting anti-slip strips on the top of the boards.
I like the flexible platform idea.
Old 08-21-2017, 03:33 PM   #12
2003 22' International CCD
Fredericksburg , Texas
Scaffolding for roof work
Last birthday I enjoyed becoming 81 years young. Just finished resealing the Fantastic Fans on a 22 ft 2002 International. Used a ladder to get and off to the roof, sat or kneeled on plywood supports. I was tired as hell after the two day job in central Texas August heat. BTW I didn't fall or falter, guess I'm in the lucky 25%. The reason to reseal the fans is that the "authorized" dealer who replaced them (hail shattered the original covers) did a really terrible installation job (2014) and both fans leaked around the "new" sealant. Both days I wished I'd had scaffolding. Not so much of safety as for easier working conditions.
jasfox is offline   Reply With Quote
Old 08-21-2017, 07:53 PM   #13
Portage to Caravan's Avatar
2014 23' FB Flying Cloud
Petrolia , Ontario
"Wooden" Scaffolding
As a retired Carpenter, I would not recommend a handyman construct his own wooden scaffold. I was one of the last few trademen who were trained to build it this way. For good reason I must add. Wood as scaffolding is extremely versatile in many situations, but it does not stand up to being moved around repetitively, and viewing the P.M. drawing I'd estimate the components are a bit light. If you're really thinking safety, get the right goods. Check around, search the adds, Craigs list, even advertise your desire for some usable frames. Someone is likely to help.
Ladders can be perfectly safe if and when they're used properly. Number one, ladders must be level and stable. If you need to excavate under one foot, or shim with stable stacks of lumber (not on loose gravel or marbles ) do so.
I built a stand off with a large foam pad for my multi function ladder, that rests on the exterior of the trailer so there are only two legs in contact with the ground. The foam pad resists sliding along the skin as well. I can reach the center of my roof without stepping on it. If you still feel the need to be "on the roof", Bob662's suggestion is a good one. If the slats can be made to reach from one framing member to another it would be all the better. I didn't read the entire article on ladders but I'll bet they found a good number of falls from ladders happen when stepping onto or off of ladders.
Good luck, and stay safe.
Portage to Caravan is offline   Reply With Quote
Old 08-21-2017, 09:59 PM   #14
1969 27' Overlander
Palm Desert , California
Just another option
Has anyone tried the Harbor Freight scaffolding?
https://t.harborfreight.com/heavy-du...old-63050.html
DesertRat223 is offline   Reply With Quote
Popular Mechanics The Airstream: Secrets of America's Silver RV aquinob Airstream "In the News" 2 07-06-2013 10:50 PM
Old Popular Mechanics on Google Books Stefrobrts Airstream History 18 11-12-2009 08:01 PM
Ahem! I begin new thread by popular request ... summerkid Off Topic Forum 13 12-20-2005 06:34 PM
