Old 11-11-2015, 06:02 PM   #1
Merkel , Texas
Numbers on Front of Trailer
I have seen them on many of the older trailers but don't know what they mean. The numbers on the top front, should I try and keep these when I polish it or what? Thanks
retiredfire is offline   Reply With Quote
Old 11-11-2015, 07:03 PM   #2
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . Welcome to our group !. . . The numbers are the WBCCI assigned numbers of a previous owner. If readable, you could contact the club to see if that number is available to you (if you're interested in BEING a member. ) They will send you new red numbers when you join to place on the trailers front & back. Hope this helps, regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 11-11-2015, 08:02 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Those big red numbers are the owner's WBCCI membership number, and have nothing to do with the trailer itself. These numbers are on both the front and back end caps of the trailer.
The red stars above the numbers each represent five years of club membership.
Brian
SuEllyn & Brian McCabe
Old 11-11-2015, 08:39 PM   #4
Merkel , Texas
Thanks for the replies, that is good info and I will look into it.
Old 11-12-2015, 10:24 AM   #5
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
Even though we have kept the same WBCCI number since it was issued to my parents in 1969 when the trailer was new I removed the numbers this fall. I am going to see how they look come spring. I've tried several compounds and techniques but the contrast between where the number was and the rest of the panels is still visible. I am avoiding using a high speed buffer to actually polish the area because then it will look even more obvious than before. I will decide in the spring what to do in terms of replacing the numbers with new ones or making a sign which we would use to display during AS events and rallies. I will say that as a couple of months have passed by the area where the numbers were seems to be fading out a bit so perhaps some sun and some time will help.
kdickinson is offline   Reply With Quote
Old 11-12-2015, 10:33 AM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
1811 here-
Affiliated with the Mississippi Unit of the WBCCI-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-12-2015, 10:42 AM   #7
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Originally Posted by kdickinson View Post
...<snip>.... I will decide in the spring what to do in terms of replacing the numbers with new ones or making a sign which we would use to display during AS events and rallies....<snip>
Just so you know, you can order a new set of numbers from International...
We mounted ours on plexi-glass and hang them from the front window when we are in a situation where they are required...(so far, only at Regional and International events...
TB & Greg and Abbey Schnauzer
#3954
Old 11-12-2015, 12:21 PM   #8
m.hony's Avatar
2013 30' Classic
To me the big red numbers is just part of owning an Airstream. They just belong.
TAC #MS-10
Airforums #70955
Old 11-12-2015, 01:19 PM   #9
moosetags's Avatar
I wholeheartedly agree. An Airstream without the big red numbers look like a knock-off.
Brian
Old 11-12-2015, 01:52 PM   #10
PeterKV's Avatar
1985 25' Sovereign
Wichita Falls , Texas
So if the red numbers are the WBCCI membership number, what are the blue numbers for?
PeterKV is offline   Reply With Quote
Old 11-12-2015, 01:59 PM   #11
Gainesville , Florida
Air forum numbers?
Old 11-12-2015, 02:03 PM   #12
moosetags's Avatar
Exactly. The blue numbers (14872) on Old Lucy that you see in my avatar is my Airforums membership number. I have not put any blue numbers on New Lucy yet.
Brian
Old 11-12-2015, 05:33 PM   #13
2006 25' Safari SS SE
LINCOLN , Nebraska
I think the numbers look tacky. I would much rather put them on a plack and show them in a window when I need to. When you are going down a highway I really don't want every AS owner to know who I am or some geek who can easily get the info too easily from the WBCCI website.
MissingLink5 is offline   Reply With Quote
Old 11-12-2015, 06:43 PM   #14
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Unless he/she is a wbcci member they can not gain access to the digital WBCCI directory that contains your name and address. If you chose to not have your name in the digital directory then no one can gain access to your name in the digital directory. You can not chose to not be listed in the hard copy directory so anyone with a hard copy can look you up.
1959 Globe Trotter - want to repaint Red numbers on front. Kim Cannon Clearcoat, Exterior Paint & Trim 3 01-25-2008 02:18 PM
Numbers on the front of AS? crdouger General Repair Forum 6 11-19-2007 10:55 AM
What those numbers on the front mean robnicol WBCCI Forum 7 01-10-2004 09:56 PM
I need numbers, Part numbers that is. thenewkid64 Airstream Motorhome Forums 1 07-19-2003 10:51 AM
Production Numbers on Front and Back? Guitars WBCCI Forum 5 11-24-2002 08:47 AM
