Old 08-06-2009, 08:20 AM   #15
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Originally Posted by Maryw164 View Post
Anyone have pics they can post of what the white roofs look like on the newer models?
Mary
Maryw164....Attached are pictures of the white aluminum roof on my 2007 25'.
ID:	84987   Click image for larger version
Name:	Airstream Roof 2.jpg
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 08-07-2009, 09:45 AM   #16
2001 16' Bambi
Seattle , Washington
Mary, I'll take a picture of my white roof this weekend and post it next week....if I figure out how to post pictures. I can also email it directly to you. Gina
beulahluster is offline   Reply With Quote
Old 08-07-2009, 10:45 PM   #17
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
2dabeach,
Thanks, the pics give me a good idea of the parameters for where to start/stop the white paint line.
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 08-08-2009, 08:07 AM   #18
CanoeStream's Avatar
St. Cloud , Minnesota
Mary, the roof pictured is different from yours in two ways. Post '93-'94, Airstreams over 22' had 6" extra width added. More significantly, roof and end cap contours flattened out at that time. You have the beautiful, more arched contours that makes new coach owners so envious. Way cool! We should probably get some input from Terry on this.
5 meter Langford Nahanni
Old 08-10-2009, 05:23 AM   #19
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I painted my 1977 Sovereign,s roof white after a bad experience at the first Rapid City International, when we only had 3 amp service available and the temperatures reached 104 degrees in the shade (and there was no shade available in the treeless parking field). I painted it white from just above the awning to the split line on the opposite side where the roof meets the sidewalls. I put no paint on the hemispheres. To the casual observer, walking past at eye level, you can not see the white paint. If you look in the archives, you will note that some of the early Wally Byam caravans to the hot parts of the world, include trailers with white painted roofs that extend well down onto the sides. These were practical people who knew that "form should follow function" and did what was practical to make their travels bearable. I even think I have seen one of Wally's personal trailers with a roof that was painted white. I have not painted my 63's roof white yet but this weekend at 98 degrees without air may have changed my mind.
Old 11-13-2009, 10:52 PM   #20
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
I need to reseal my vent on our 08, what type of sealant should I use?
subfan1 is offline   Reply With Quote
Old 11-17-2009, 07:21 PM   #21
sierrajb's Avatar
Arlington , Texas
I Did That!
Originally Posted by easyride View Post
I think the white roof would reflect a lot of heat,I`m thinking of putting Elastameric
[mispelled] on my Overlander ,has anyone done this,and with what results?
Dave
I coated my 75 Argosy with 4 coats of Elastomeric covering. It has several advantages: cooler, seals better, looks great. Keep it clean and apply a new coat every few years and you'll have no problems at all.
Airstreams are like a box of chocolates....
sierrajb is offline   Reply With Quote
Old 11-17-2009, 07:43 PM   #22
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Would you believe I missed this thread the first time around?
I painted ours with the local version of Kool Seal, known as Henry Seal. My painting pretty much followed the painted areas of the newer trailers, though it did extend a bit further fore and aft, down to the awning railo on the curb side, and along the edge of the center roof panel on the street side. It's been pretty effective keeping the temps a bit lower, and if it ever rains, we'll know if it leaks...
Old 11-17-2009, 08:01 PM   #23
sierrajb's Avatar
Arlington , Texas
Cool You Trained Me Well!
Terry, miss being on the forum and hearing all your genius insights! Hope all is well! It sounds like I treated the top of my Agrosy in the same way you did yours. Guess great minds think alike!
Now, I'm gathering info about cleaning and repainting all the "plastics" that have turned yellow (end caps, bathroom sink, countertop, etc.). So much info to filter through, it's gonna take some time to find someone who's successfully repainted the interior plastics. Take care!
Old 11-17-2009, 08:02 PM   #24
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by beulahluster View Post
My white roof seems really soft and flexible. It does not feel like it is aluminum underneath. Is this your experience too? I can buckle it in out out with just my hand. What's up with that? Gina
It's aluminum. I was on mine this afternoon putting a cover on my AC unit.
It flexes stay near the rivet lines and off the end caps. You will be ok.
Michelle TAC MT-0
Sarah, Snowball
Old 11-17-2009, 10:53 PM   #25
2dabeach's Avatar
subfan1....Airstream advised me to use Sikaflex White 721 UV on the roof vents of my 2007 Safari
Old 11-18-2009, 06:34 AM   #26
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
I have been researching a way to coat my roof white as well. I've got 5 gallons of a product called Ceramiflex on order. It is made by Sealoflex--they manufacture products to waterproof roofs, decks, ponds, etc. I have used them for years with good success. www.sealoflex.com
The Ceramiflex offers the advantage of having ceramic particles--makes for a highly reflective surface in white which will hopefully make the interior of the trailer even cooler than using white aluminum or a KoolSeal type product.
It will also stick to non ferrous metals with no preparation other than a good cleaning. Their other products work similarily--I have a water proofed deck on my house that I used Sealoflex on 5 years ago and it has held up well in full sun. Some was applied to raw aluminum flashing and it is still perfectly intact. No streaking either (do not want white streaks on sides of trailer, ever).
The coverage is heavy (50 square feet per gallon) and this will give some good insurance against water intrusion on the roof.
Anyone else have any experience with ceramic based products? Sound like a good way to go?
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 11-18-2009, 07:53 AM   #27
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Me too!
Bill, I like the sounds of this material. Are we sure about no streaking...I could not find that ref on their web site. I am about to start my reseal/paint on the top of the 94 Sovereign. I am ready now....are you about to start?
Old 11-18-2009, 08:18 AM   #28
Maryw164's Avatar
1972 31' Sovereign
Ceramiflex vs. Reflectowhite
What made you decide to go with the Ceramiflex instead of the Reflectowhite? Are there added benefits with the Ceramiflex? I didn't see any solar absorptivity info on the info page for the Ceramiflex, only for the Reflectowhite?
Thanks, Mary
Happy Trailering !
Sealing preparations for Land Yacht Roofs phred Land Yacht/Legacy Motorhomes 3 01-07-2005 07:32 AM
Painted AS Roofs ardenrj Clearcoat, Exterior Paint & Trim 7 12-09-2004 07:17 AM
white roofs? sovereign Airstream Trailer Forums 19 08-02-2004 03:40 PM
White roofs and number placement till WBCCI Forum 4 02-05-2004 07:34 PM
White Plastic letters for airstream grogan Clearcoat, Exterior Paint & Trim 1 06-25-2003 01:35 PM
