Old 04-30-2013, 11:34 PM   #1
1967 26' Overlander
Springfield , Oregon
Question New plumbing vent covers
We just recently purchased a 1967 Overlander and noticed while I was polishing the roof area that I had plastic plumbing roof vents and they were cracked and problably leaking.
I purchased from Inland RV new plumbing vent covers in aluminum, I also got a rubber gasket that is slighly larger than the covers footprint and also some screen. It did not come with instructions, does anyone know how this project is supposed to be completed? Should I use sealant? Rivits? Just the rubber gasket? I need help.
Will
Carrara68 is offline   Reply With Quote
Old 04-30-2013, 11:39 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Welcome.. do not use 'silicone' products.
Remove old, clean up as best you can with scraper and mineral spirits. You can follow up with some acetone or denatured alcohol to let the new sealant have good 'bite'.
Sikaflex or similar product will do the job..Dicor is another product which may fit the bill.
Use sheet metal screws.. preferably stainless to minimize corrosion. Use sealant on both sides of gasket .. not too much...clean with solvent mentioned above.
Screen is used to block 'critters' from entering the area...
Old 05-01-2013, 08:21 AM   #3
1967 26' Overlander
Thanks for the information cwf. I will follow your advise.
Old 05-01-2013, 12:30 PM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Gutter sealant will work too. HD and Lowes carries this stuff.
1966 Overlander
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
Our AIRSTREAM and TIN CAN TOURIST Rallys
